Browse Forums Landscape & Garden Design Re: Fixing gaps under colorbond fence - anyone used this? 6May 12, 2016 10:39 pm Well that all sounds promising! Hope it goes well and definitely let us know how it goes Re: Fixing gaps under colorbond fence - anyone used this? 7May 13, 2016 9:47 am This is a better idea and it can actually work as a retaining wall. I'd have my doubts on that vertically oriented stuff http://www.allperthfencing.com.au/fenci ... s/plinths/ Re: Fixing gaps under colorbond fence - anyone used this? 8May 13, 2016 10:28 am Althom This is a better idea and it can actually work as a retaining wall. I'd have my doubts on that vertically oriented stuff http://www.allperthfencing.com.au/fenci ... s/plinths/ To be honest they look like two different products. The plinths look good for heavier duty retaining, yet they have to be installed when the fence goes in, or you have to pull your fence apart to fit them. They also look like a bit of overkill just to fill smaller gaps under your fence that the trim panels do. The trim panels can be fitted to your fence without having to pull it apart. In my quest for a solution to my fence spaces, I've looked at the plinths and I've seen plenty of cases where they are fitted to some fence lines, and further along on the same fence, gaps have been left open. Being that they are different products for different applications, I'd say they could be used in conjunction on the same fence. Re: Fixing gaps under colorbond fence - anyone used this? 9May 14, 2016 8:32 pm I'm suspicious you are actually the seller and are using this site to advertise your fence panels. And you're doing a find job disguising it. My reason, you have only 8 posts and all are about this one topic. Seems a bit strange to join a forum to ask if anyone has used a particular product which is only advertised on gumtree. Prove you are not the seller.... Re: Fixing gaps under colorbond fence - anyone used this? 10May 16, 2016 9:58 am Nice one, mate. You do see I joined two years ago, right? Jet fuel doesn't melt steel beams! Re: Fixing gaps under colorbond fence - anyone used this? 11May 24, 2016 11:38 pm Well, almost didn't come back to post this. I had him come out and show me. It's pretty much just what I'm after and easy to fit, but I am a homehandyman. Maybe when I've put some in, I can post some photos of the result and be accused some more Cheers. Re: Fixing gaps under colorbond fence - anyone used this? 12May 25, 2016 10:07 pm That would be great Homehandyman. Never mind the paranoid people on here! No. The same paint that they paint the wall with will be fine. The builder probably had every intention to paint it and not leave it black. 7 2882 Brass fly wire, you will need to cut it, shape it and jam it into brick slots 1 8058 Building Standards; Getting It Right! Hi, sorry if this is the wrong place - I’m new to the property/building journey (trying to buy my first home) so not sure where/who to go with these sorts of… 0 20163 |
