Browse Forums Building Standards; Getting It Right! Re: Gaps in bricks around Windows/doors new build. 7Mar 21, 2016 6:19 pm shanis33 wood bang Angles and trims What about where the bricks butt up to one side of the window but not to the other. A trim will look stupid That is a silly idea, what is going to hold your brick in place? It's going to crack and fall apart Re: Gaps in bricks around Windows/doors new build. 9Mar 21, 2016 6:22 pm jai.m Builder will put in same color trims and you won't notice or that was what I've been told Ok but they will be uneven as you can see from the pic one side butts up to brick and the other has big gap. So therefore a trim will make one side of the window larger. Re: Gaps in bricks around Windows/doors new build. 10Mar 21, 2016 7:01 pm I agree, the sides should be more even. My Reno has a similar issue above the sliding doors - we stuffed up the measurements for the doors and I have to put a moulding in. But I'm a DIYer not a builder. How high is the door. Re: Gaps in bricks around Windows/doors new build. 11Mar 21, 2016 7:29 pm Front door? 2110 I think. I think they have ordered wrong too or placed it wrong. Before it was wrapped or anything there was massive gaps between the timber framing and the frame of the window. Sorry to hear you have to put moulding on yours Re: Gaps in bricks around Windows/doors new build. 12Sep 15, 2016 3:30 pm any news? How did it all go? The gap around the window to the frame should be 20mm. A&L make windows to brick opening sizes. You should not need infills. "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 7 3505 B, You and I know each other well outside of the forum, and I really like you. So I am not meaning any ill will by the following comments. I have been with you on this… 7 1792 Brass fly wire, you will need to cut it, shape it and jam it into brick slots 1 8056 |
