Browse Forums Building A New House Re: Building Metricon Glendale 42 Limited Edition in Geelong 13Jan 15, 2016 12:43 pm Orpheus Which facade are you getting? Are you getting hebel or upgrading bricks? @ Orph build thread: viewtopic.php?t=78328 Dream Metricon Glendale 38 (Sydney)! going with peninsula facade. Top will be render over eps cladding. Thinking of possibly upgrading brick to the front to cat 4 moonshadow, not sure if going ahead with render on pillars and around garage. It's $4k, might get it done post handover? Build thread - viewtopic.php?t=81517 Metricon Glendale 42 Limited Edition Re: Building Metricon Glendale 42 Limited Edition in Geelong 14Jan 15, 2016 12:46 pm kylz4 vintay68 kylz4 So I thought after stalking everyone else's threads for the past few months that I should finally start my own! We are building Glendale 42 LE which is slightly different to standard. Some of the changes that we have made... 2.55 ceilings to lower floor Widened garage by 1m Extended alfresco to edge of house and 1 meter out back Extended back of kitchen bench to be same as standard plan 1200 pivot entry door Timber handrail and bottom two treads and stainless steel balustrade Cavity slider to kitchen Upgraded sliding door to stacker door to alfresco Increased size of family room window Under stair storage Zoned heating Evaporative cooling Changed ensuite layout to be same as standard Cavity sliders to ensuite Extended bathroom vanity Removed robe doors from WIR so we can fit it out properly later. Potentially adding on rear garage roller if we have room Home complete package including flooring/blinds/driveway/stone to kitchen and 1m overhead cupboards to each side of range hood (which we extended all the way) and 900mm appliances I'm sure there is more but that's all I can think of right now! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ We are going with the peninsula facade but not sure if pillars and garage will be rendered yet, depends on final quote! Hoping for this kind of look colour wise Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ We have our colour selection appointment on the 29th, wanting whites/greys/timber. Can't wait!! Not sure how to put a link to this thread in my signature, can anyone help? Hi kylz4, Can you advice the quoted price for under stair storage and the timber hand rail? I've spoken to my sales consultant and was advice under stairs storage is not possible. Thanks Sent from my SM-N910G Under stair storage was quoted at $634 We were quoted just under $2k to do timber handrail and ss balustrades Build thread - viewtopic.php?t=81517 Metricon Glendale 42 Limited Edition That's a good deal. The under stair storage door is facing the kitchen island right? When will the built commence? Sent from my SM-N910G Re: Building Metricon Glendale 42 Limited Edition in Geelong 15Jan 15, 2016 12:53 pm Not sure where they are putting door yet, I'd probably prefer it in hallway? Build thread - viewtopic.php?t=81517 Metricon Glendale 42 Limited Edition Re: Building Metricon Glendale 42 Limited Edition in Geelong 16Jan 15, 2016 7:33 pm Oh and build will probably commence around late March/early April is say once we've done colours, contracts and developer and council approvals Build thread - viewtopic.php?t=81517 Metricon Glendale 42 Limited Edition Re: Building Metricon Glendale 42 Limited Edition in Geelong 17Jan 15, 2016 7:42 pm kylz4 Oh and build will probably commence around late March/early April is say once we've done colours, contracts and developer and council approvals Build thread - viewtopic.php?t=81517 Metricon Glendale 42 Limited Edition Yay! That's pretty quick and will arrive pretty quickly. Makes use you identify all changes, upgrades, colours, external and internal selections before hand. Also consider electrical design/selelctions. @ Orph build thread: viewtopic.php?t=78328 Dream Metricon Glendale 38 (Sydney)! Orpheus Building the Metricon Glendale 38|Sydney Re: Building Metricon Glendale 42 Limited Edition in Geelong 18Jan 15, 2016 7:45 pm Yes it will be here pretty quick! Will take our time and go through contract with a fine tooth comb. Trying to work out electrical currently. How many downlights would be needed to main living, hallway and sitting room do you think? What is the cost per downlight? What wattage are they? Build thread - viewtopic.php?t=81517 Metricon Glendale 42 Limited Edition Re: Building Metricon Glendale 42 Limited Edition in Geelong 19Jan 15, 2016 8:03 pm kylz4 Yes it will be here pretty quick! Will take our time and go through contract with a fine tooth comb. Trying to work out electrical currently. How many downlights would be needed to main living, hallway and sitting room do you think? What is the cost per downlight? What wattage are they? Build thread - viewtopic.php?t=81517 Metricon Glendale 42 Limited Edition Have a look at my thread for my electrical plan to get an idea. We used all LEDs (11W for bedrooms & 13W for living areas). Average is 1 LED every 1-2m is recommended. @ Orph build thread: viewtopic.php?t=78328 Dream Metricon Glendale 38 (Sydney)! Orpheus Building the Metricon Glendale 38|Sydney Re: Building Metricon Glendale 42 Limited Edition in Geelong 20Jan 15, 2016 9:39 pm kylz4 Yes it will be here pretty quick! Will take our time and go through contract with a fine tooth comb. Trying to work out electrical currently. How many downlights would be needed to main living, hallway and sitting room do you think? What is the cost per downlight? What wattage are they? Build thread - viewtopic.php?t=81517 Metricon Glendale 42 Limited Edition Had a word with the lighting and was inform the undermention. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ $90 led distance per led - 2 to 2.5m Light angle - 155 degree lumens - approx 900lm Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ $70 led Distance per led - 1.5m Light angle - 110 degree Lumens - approx 600lm. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ They also have oyster light that cost about $100 each. Hope that helps Sent from my SM-N910G Hi, First of all, thank you to this community for sharing your thoughts and opinions. We are in early days of our pre-contract stage for Metricon Doulton and we are… 0 12769 Hello All 🙂 We are planning to start our journey of construction our first home. We zeroed down on Metricon and henley homes based on design suitable for our lot and… 0 9693 We don’t live in VIC so want to know the exterior colours of Lumiere display so we can see it at the paint shop. Not building with Metricon so my request went… 0 19743 |
