Browse Forums Bathrooms and Laundry Re: Upstairs bathroom, tile size to avoid flexing issues 2Mar 13, 2015 10:02 am The bathrooms i have done we use 18mm cement sheeting on the floors. Some builders use just the yellow or red tongue flooring which is okay for under carpet but in wet areas you should use the cement sheeting to avoid the issue. With my knowledge it wouldn't matter what size tiles you use on the floor, they should never lift if laid correctly and if they did it should be under the warranty of the house or bathroom builder. The only impact larger tiles have is achieving the correct fall into drains. Re: Upstairs bathroom, tile size to avoid flexing issues 4Mar 14, 2015 9:32 am Hi guys, we have a tiled bathroom upstairs , and the tiles lifted / became loose after 6 years. It also got very hot up there. After removing 24+ tiles, we found they glued them straight into yellow tongue. And no waterproofing either. Recommend cement sheeting. You will have trouble otherwise. I suspect they came loose when the house was settling.... Building a Madison 45 with Porter Davis Madison 45 Blog (Send me a PM with your email address to be added) Re: Upstairs bathroom, tile size to avoid flexing issues 6Mar 20, 2015 10:51 am ![]() Timber standard substrate upstairs. Had friends whose tiles became loose in their upstairs bathroom due to flex in the flooring. Just as a consideration because we are potentially in the same boat with 2 bathrooms upstairs, would having larger sized tiles make a difference in combating flex? As others have said its nothing to do with the tiles, its just an extremely poor job done by the builder. Cement sheet should always be used! Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com I have a home gym at home. It weights 150KG including the weight stack. I'm a big boy, around 150KG myself. I was thinking about moving it up stairs to the second… 0 6753 Possibly both depending on the sizing. Idea of working from the centre is that you dont have a 20mm thin tile at one end and a 400mm at the other end. A quick search on… 3 9130 |
