Browse Forums Bathrooms and Laundry Re: Block off old taps 2Jan 12, 2015 8:58 pm The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Block off old taps 4Jan 12, 2015 10:17 pm DIY69 Thanks - that is what I have but how does that stop the hot and cold water mixing inside the wall behind the faucet fitting. Do I leave half the tap fitting in or something like that? Not done that myself (only sealed off individual taps) but I would assume you could use the plug to hold a tap washer down against the seat. The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Block off old taps 7Jan 13, 2015 9:29 am DIY69 plumber may be the only answer, Legally...yes! You also have to be very aware that dead ending pipes can cause Legionellosis. A plumber should eliminate any piping dead ends. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Bathroom renovation will likely include a back-to-corner bath and we’re considering a freestanding tap with hand-held shower such as the picture included. My hesitation… 0 25176 1 3450 Thanks for much mate. I see that you do cabinets before flooring. For timber flooring, for most parts it's fine because it's got base plates, and for door jabs you can… 7 13752 |
