Browse Forums Bathrooms and Laundry Re: D'oh!! misaligned ensuite basins 2Jul 06, 2014 9:32 am Owner Building at Jimboomba Woods in Logan City Qld. Blog : http://bandlnewhomebuild.blogspot.com H1 thread : viewtopic.php?f=38&t=68283 . Re: D'oh!! misaligned ensuite basins 3Jul 06, 2014 9:47 am 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: D'oh!! misaligned ensuite basins 4Jul 06, 2014 11:08 am You will probably find that the window has been placed as per half a bricks dimensions. Project Home Builders generally work out wall lengths and heights, window sizes and placement according to whole brick and half brick sizes so they don't have to pay the brickie to cut bricks. I bet if the window was moved half a brick ( 115mm ) to the right it would be spot on. Stewie Re: D'oh!! misaligned ensuite basins 6Jul 06, 2014 12:22 pm The obvious way to fix it is to move the whole vanity to the left and centre the window between the basins but I gather that is not possible? The brickwork is done as Stewie says and if the window shows like this on your plans and you have signed off on them then it may be yourself who has inadvertently stuffed up. However, if the window on the plans is centred you must insist that it be fixed. When we got the first draft of our plans the window in the loo was off centre and like you it would have driven me barmy so I insisted it be moved. Such a tiny alteration to paperwork but see the result below. http://i1055.photobucket.com/albums/s507/grumblebum54/Toilet_zps7bf329b6.jpg Regards, Grumbles Re: D'oh!! misaligned ensuite basins 7Jul 06, 2014 1:14 pm Thanks for all the comments guys! Stewie D You will probably find that the window has been placed as per half a bricks dimensions. Project Home Builders generally work out wall lengths and heights, window sizes and placement according to whole brick and half brick sizes so they don't have to pay the brickie to cut bricks. I bet if the window was moved half a brick ( 115mm ) to the right it would be spot on. Stewie Good point there Stewie! Will go down there again today and measure it all up before I call them tomorrow. Re: D'oh!! misaligned ensuite basins 8Jul 06, 2014 1:14 pm grumblebum54 The obvious way to fix it is to move the whole vanity to the left and centre the window between the basins but I gather that is not possible? The brickwork is done as Stewie says and if the window shows like this on your plans and you have signed off on them then it may be yourself who has inadvertently stuffed up. However, if the window on the plans is centred you must insist that it be fixed. When we got the first draft of our plans the window in the loo was off centre and like you it would have driven me barmy so I insisted it be moved. Such a tiny alteration to paperwork but see the result below. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Good point. Double checked the final drawing and the window is right in the middle of the two basins - so there's no mistake there. Re: D'oh!! misaligned ensuite basins 10Jul 07, 2014 9:15 am Makes you wonder why the cabinet maker didn't bring this up, when check measuring the job. Could have been tackled before the cabinets were manufactured. Quality is like buying oats. If you want good,fresh oats,you'll pay a fair price. However,if you can be satisfied with the oats that have already been through the horse, that comes a little cheaper. Re: D'oh!! misaligned ensuite basins 11Jul 25, 2014 8:50 am GBDesign Makes you wonder why the cabinet maker didn't bring this up, when check measuring the job. Could have been tackled before the cabinets were manufactured. Project builder, plans drawn, same plan as tens if not hundreds of the same houses. Cabinet maker doesn't care, he has done what is asked of him, so why rock the boat? Extra work & time involved to change the cabinet- approach the builder, who will approach the client, get variation signed off, etc. and sometimes the client doesn't even care or even notice it. It would bug the crap out of me everytime I use it. Re: D'oh!! misaligned ensuite basins 12Jul 25, 2014 8:52 am I think this will also annoy me.. are the tiles going to sit over the basin, or is there going to be a very small gap between the basin and the tiles? It also doesn't look like wet area plasterboard has been used either. Re: D'oh!! misaligned ensuite basins 13Jul 28, 2014 2:09 pm GBDesign Makes you wonder why the cabinet maker didn't bring this up, when check measuring the job. Could have been tackled before the cabinets were manufactured. There is another way to look at the bowl positions. From the cabinet makers point of view they are where they should be. They are centred on the two cabinet doors below on both sides. If one bowl was moved it would look strange on the vanity. It really looks like the window position wasn't clearly though about! Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com the step up is 30mm and wanting it to be flat . how much does the concrete have to be lowered .we plan on removing bath and lenghten shower and adding seat. the old bath… 0 12641 if i have understood your dimensions correctly my suggestions include using the smallest toilet and wall hung handbasin eg Caroma Urbane with in wall cistern, small wall… 1 8377 |
