Browse Forums Building Standards; Getting It Right! Re: Building Code Advice 7Jun 30, 2014 7:31 pm Thank you all, I will bring this up with the site supervisor. I should add that the trusses have also been nailed in places from non load bearing wall up through to the trusses which I also have been advised being incorrect.? Re: Building Code Advice 8Jul 01, 2014 12:35 pm Why do you ask the question 'Vouge' Peter Clarkson - AusDesign Australia www.ausdesign.com.au This information is intended to provide general information only. It does not purport to be a comprehensive advice. Re: Building Code Advice 10Jul 01, 2014 5:59 pm Vouge Thank you all, I will bring this up with the site supervisor. I should add that the trusses have also been nailed in places from non load bearing wall up through to the trusses which I also have been advised being incorrect.? No trusses should be in contact with NLB walls what so ever and there should be at least a 10mm gap between them. The only exception are the above mentioned "L" brackets and slip blocks, both must be correctly installed to allow slight movement of the truss independently of the walls. Just be sure you aren't looking at a slip block or similar (pics would be handy on this item) Quote: As of now (frame trusses & roof on being bricked up as we speak) they have not been fitted and want to ensure that if the need to be fitted I am armed with the appropriate advice. Refer to my post above. It's all there. The diagram out of the Pryda installation guide is straight out of AS4440. hey nedket, We have a similar lot like yours . just wondering how is it going with your DA application, is the Blue line is the correct solution (offset the rear boundary… 1 10160 CDC Housing Code 3 When to apply Floor Area external face of wall vs Gross Floor Area internal face of wall. Reading thru CDC Housing Code 3, lets take a lot 915sqm.… 0 17561 |
