Browse Forums Bathrooms and Laundry Re: Raised floor in bathroom 7May 24, 2014 10:23 am Saint Mike Checked out the new display houses - couldn't believe they had hobs in showers and the ledge talked about above. So easy to do away with them yet they still do it ! 100% correct, but it's all part of keeping build costs to a minimum but when you want to change something like that they can charge you for it. Tis the project industry way. Re: Raised floor in bathroom 8May 24, 2014 12:12 pm mgilla Saint Mike Checked out the new display houses - couldn't believe they had hobs in showers and the ledge talked about above. So easy to do away with them yet they still do it ! 100% correct, but it's all part of keeping build costs to a minimum but when you want to change something like that they can charge you for it. Tis the project industry way. AND ... they had about 24+ lights in kitchen / family area - where you might have 6 - 8. Re: Raised floor in bathroom 9May 25, 2014 10:04 am Quote: However it's not simply a case of making a section lower, it does require to be included in the slab design as there's a step down in the mesh that has to be taken into account. Anytime we've done it in the past the engineer has been happy for us to excavate an extra 40mm in that area and simply bend the reo to suit. As long as we maintained the slab thickness and cover for the reo he was happy. I recall him saying though that any step down over 50mm needed the mesh cutting and cranked rods to be used which as you say would have added a bit more to the cost. Stewie Re: Raised floor in bathroom 10Jan 21, 2015 2:21 pm I'm interested in this topic coming close to signing our final plans to go to the engineer. I am unsure how to even understand if there is likely to be a set down other than ask the architect or his draftie. We are meeting them this afternoon so I am sure they will explain. I'm still unsure reading this if it is easier or more difficult to achieve a flush finish on slab or bearers and joists. We are doing the house on bearers. One builder we met up with said bearers is more complicated than slab to achieve this. But we decided not to use him and I think he doesn't prefer to build in that way. The draftie did ask us to carefully specify the floor finishes - timber, carpet, ceramic tiles to wet. I know this needs to be included in the schema but could this reason also be why she asked? Re: Raised floor in bathroom 11Jan 21, 2015 3:41 pm It's not hard to achieve it using a raised platform ie bearers and joists. Where the wet areas are you simply have those bearers set down 30 -40mm with the corresponding joists sitting on top. Or in those areas depending on the span you may get away with the bearers all the same level and just using smaller joists. As they have asked already, you need to specify what you are having for floor coverings in which rooms so they can pass that info onto the builder when they start building your house. I should do a detailed section through a floor showing this as this question crops up on a regular basis. Stewie Re: Raised floor in bathroom 12Jan 21, 2015 5:59 pm We drop down the up stairs wet areas in a lot of houses we build. It is a fairly easy process but can be an expensive process also. Its not just a case of making the wet area 60mm lower, it may be you need to increase the joist size of the remaining floor by 60mm. Re: Raised floor in bathroom 13Jan 21, 2015 7:23 pm We're having this done in our new build, bearers and joist flooring, builder very happy to do. As mentioned you just need to let your builder know. We are using a custom builder. Custom build Northern NSW viewtopic.php?f=31&t=72217 Re: Raised floor in bathroom 14Jan 22, 2015 10:00 am TraceyWayne We're having this done in our new build, bearers and joist flooring, builder very happy to do. As mentioned you just need to let your builder know. We are using a custom builder. yes we are also having custom. Does it need to be included at engineering stage? Re: Raised floor in bathroom 15Jan 22, 2015 10:18 am Quote: Does it need to be included at engineering stage? It should be or at least the engineer should be aware of what you are trying to achieve and it wouldn't matter if you were having a slab or raised timber floor. Stewie Re: Raised floor in bathroom 16Jan 22, 2015 8:19 pm Yes, engineer aware as is builder, draftsman and anyone remotely involved with the build, I want those floors haha Custom build Northern NSW viewtopic.php?f=31&t=72217 Re: Raised floor in bathroom 17Jan 23, 2015 5:50 am Stewie D Quote: Does it need to be included at engineering stage? It should be or at least the engineer should be aware of what you are trying to achieve and it wouldn't matter if you were having a slab or raised timber floor. Stewie Thanks stewie and all. Re: Raised floor in bathroom 18Feb 08, 2015 9:54 pm The builder we were originally going with outright said no they would not consider it (pretty common project builder). We changed to another project builder and was easy to arrange. They are doing this in both bathrooms and the laundry and will charge us $750 all up so was happy with that. They determined the flooring height (slab) based on the measurements of the flooring that we are installing. Can't believe how cheap some builders are! thanks chippy! here is the back of the wall which has not been backfilled yet. Here is the same back of the wall taken from the other end, behind the steps. As you… 5 2165 Possibly both depending on the sizing. Idea of working from the centre is that you dont have a 20mm thin tile at one end and a 400mm at the other end. A quick search on… 3 8916 |
