Browse Forums Building Standards; Getting It Right! 1 Mar 12, 2014 4:22 pm Hi, Does anyone know if the Australian Standard AS1428 "Design For Access and Amenity" Is applicable to residential development? I am aware of its relevance to commercial construction projects however I have to build a disabled access ramp at my personal home to accommodate an elderly family member and was concerned I may have troubles selling the house in the future if I have a ramp which does not comply. Thanks Re: Disabled Access Ramps Compliance with AS1428 2Mar 12, 2014 5:17 pm I have a long term tenant in a unit that required access ramps front and back. The ramps fitted are compliant, detachable and easily removed without property damage. I still have the relevant paperwork here somewhere. I will have a look when I get a chance. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Disabled Access Ramps Compliance with AS1428 3Mar 13, 2014 9:42 am Compliance with AS1428 is not a requirement for a class 1a dwelling. Ramps are required to be 1:8 or flatter with balustrade requirement as per normal. Peter Clarkson - AusDesign Australia www.ausdesign.com.au This information is intended to provide general information only. It does not purport to be a comprehensive advice. I can totally relate to your shed project struggles—I recently tackled a similar ordeal, and it was quite the journey. Navigating through all those regulations and hoops… 4 8006 From a pure legal perspective, if you've signed the variation, it is a very high bar to have it set aside. No-one can give you legal advice on a forum, but you would need… 3 5620 |
