Browse Forums Building A New House Re: Porter Davis homes 9143Feb 18, 2014 3:52 pm Thanks. Just checked online. The LEDs are like $45 each. The 50w downlights are around 900 lumens. We might have to replace it afterwards with something like the brightgreen or even the ledified globes. Just a couple of quick points as well about the downlights: - 550 lumens is really not very bright and the beam angle is very narrow, it is disappointing that PD can't offer better LED downlights given the price point that they are charging. - The downlights PD provide are 70mm so its quite annoying if you're looking to do a quick swap over to newer/brighter downlights down the track as most are usually 90mm - When PD installs the downlights, they unfortunately hardwire the downlights. These days you can buy replacement downlights that come with a normal plug and all you need to do is plug it into a socket and that's it! This means that you wouldn't need to have an electrician perform the work. I'm actually in the process of changing over some of the downlights and also installing downlights upstairs - I've received quotes for $75 an hour (+ GST) from electricians and they reckon they can do 8-10 downlights per hour. Might be something to keep in mind as an alternative. Hi Serenity_Now, What downlights are you replacing them with? That's very annoying about the way it's installed as well? I was thinking of replacing them with the DR700 GU10s (http://brightgreen.com/au/led-lights/dr ... plications) after handover. Particularly in the Lounge Room, Family and Kitchen areas. Don't mind if the corridors have the crappy ones provided by PD. I don't know why they persist with these lights. Even in display homes they're barely throwing any light. Re: Porter Davis homes 9144Feb 18, 2014 4:12 pm Hi Serenity_Now, What downlights are you replacing them with? That's very annoying about the way it's installed as well? I was thinking of replacing them with the DR700 GU10s (http://brightgreen.com/au/led-lights/dr ... plications) after handover. Particularly in the Lounge Room, Family and Kitchen areas. Don't mind if the corridors have the crappy ones provided by PD. I don't know why they persist with these lights. Even in display homes they're barely throwing any light. Hi Bramsy, I'm actually ripping out the downlights PD installed for me downstairs. The downlights that PD have supplied work well in small rooms e.g. powder room, laundry, bathrooms etc. But in an open area like lounge, kitchen etc. they're pretty abysmal in terms of brightness! Whilst I had to pay for PD to install the downlights downstairs, it means that I can now widen the 70mm hole to a 90mm hole and get proper decent downlights and not worry about hitting any beams etc. I'm opting to install Martec 16w Shadowline downlights (1060 lumens and 120 degree angle) in some areas and Samsung 13w downlights (880 lumens and 120 degree angle) in some other rooms. I managed to purchase the Martecs for $42.90 each and $26.40 for the Samsungs. Re: Porter Davis homes 9146Feb 18, 2014 4:41 pm Are u installing yourself or electrician to do? Electrician - but I'm getting them to install plug bases for all the downlights that they're either installing or moving for me. That way in the future, if I ever need to change the downlights I won't need to call them back. Re: Porter Davis homes 9147Feb 18, 2014 7:25 pm Are u installing yourself or electrician to do? Electrician - but I'm getting them to install plug bases for all the downlights that they're either installing or moving for me. That way in the future, if I ever need to change the downlights I won't need to call them back. have you asked if PD can do the plug base versions instead to save time? Re: Porter Davis homes 9148Feb 18, 2014 8:18 pm Are u installing yourself or electrician to do? Electrician - but I'm getting them to install plug bases for all the downlights that they're either installing or moving for me. That way in the future, if I ever need to change the downlights I won't need to call them back. have you asked if PD can do the plug base versions instead to save time? They probably could as they do install plug bases for items such as exhaust fans, but by the time we realised it was too late Re: Porter Davis homes 9149Feb 18, 2014 9:16 pm Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Thought it may be time to share some photos, our floors were laid yesterday looks amazing (in my opinion lol} Re: Porter Davis homes 9151Feb 18, 2014 9:29 pm Thank you, after so long of choosing things it's nice to see it finally come together Re: Porter Davis homes 9152Feb 18, 2014 11:22 pm Sam, your place is looking great. When is your handover? Re: Porter Davis homes 9154Feb 19, 2014 10:47 am Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Thought it may be time to share some photos, our floors were laid yesterday looks amazing (in my opinion lol} Hi S Your house looks stunning May I ask what floorboards you use? Also, what you put on the wall (tile?) ? it looks shinny ![]() Re: Porter Davis homes 9155Feb 19, 2014 6:11 pm Sam - the home is looking awesome! We picked the same feature tiles (green mosaics) for our bathroom but only used in the shower niches - your layout of them looks amazing! Re: Porter Davis homes 9156Feb 19, 2014 6:20 pm Sam, it's all looking great. It's hard to wait when a few things and it would all be done and you could move in. PCI must be soon for you? Re: Porter Davis homes 9157Feb 19, 2014 7:39 pm mirzSam, your place is looking great. When is your handover? Thanks Mirz, we're expecting around the 3rd, carpets getting installed today they look great. Our SS has been fantastic, he thinks we may get in a little earlier. Although some bugger stole our rear roller door overnight and dumped all their rubbish grrrr still can't ruin my mood tho ![]() Re: Porter Davis homes 9158Feb 19, 2014 7:44 pm Hi S Your house looks stunning May I ask what floorboards you use? Also, what you put on the wall (tile?) ? it looks shinny [/quote]Thank you Scott, the floor boards were a bonus, I have a habit of being able to walk into a showroom and pick the most expensive of everything. I saw these floors in the display home at greenvale and surprise surprise they were category 1 still very very expensive IMO they are merbau 1strip. They change colors in all the sunlight. They're very dusty I can't wait to clean ![]() Re: Porter Davis homes 9159Feb 19, 2014 7:47 pm Oops sorry I forgot the feature tile in the entrance way it is a porcelain polished groved stratos in the colour of wet cement Re: Porter Davis homes 9160Feb 19, 2014 7:50 pm Thank you Claire, we changed it at the last moment and I really doubted it but love how it turned out, your so close as well. It's hard to be patient when you can see the finish line check out the facebook page Building with Better Built - it helps! But i've heard both builders are fantastic. 1 160075 Yeah, that’s fair to be uneasy about it. We had similar wording pop up early on and our conveyancer pushed back hard. A few things were amended once we queried it,… 3 2640 Hi paul smith, Did you go ahead with Dezire Homes? I am in the market now and was looking for some feedback? Thanks 4 176470 |
