Browse Forums Building A New House Re: Things you forget - summary page 32 43Oct 06, 2008 3:01 pm Timbacare - Save Your Furniture! We can help you revive timber furniture & flooring www.timbacare.com.au Re: Things you forget - summary page 32 44Oct 06, 2008 3:21 pm http://www.rentfreeatlast.blogspot.com/ Building in Berwick ----------------------------------------------------------- "Flying is learning how to throw yourself at the ground and miss." - Douglas Adams Re: Things you forget - summary page 32 46Oct 06, 2008 4:44 pm http://www.rentfreeatlast.blogspot.com/ Building in Berwick ----------------------------------------------------------- "Flying is learning how to throw yourself at the ground and miss." - Douglas Adams Re: Things you forget - summary page 32 52Oct 06, 2008 8:48 pm miss81 - skirting boards to be laid after handover (gee they are cruel) Is there a standard gap they leave between slab and skirting to account for tiles, carpet, floorboards etc? Great thread! Re: Things you forget - summary page 32 53Oct 07, 2008 1:18 pm This thread IS great! I'm sure all our answers are too late for the OP but the suggestions are helping me and many others I'm sure...
Some things we added: * Insulation between downstairs and upstairs (for sound proofing) * Doors to close off open planned areas - once you have a teenager, you'll appreciate them! * We're getting all of our tiles cleaned and sealed as I'm tired of having stained grout, especially around the toilet! * Drawer and shelf towers in wardrobes * gas point to alfresco area * Outdoor light near clothesline * Pay TV, TV and Phone points in every single room - you never know... * IXL tastic light/heater/fans in bathrooms * overhead/underbench cupboards in laundry * We're having a custom built huge floor to ceiling shelved cupboard built in our garage, along the entire rear wall of the garage - for our toddler pool, suitcases and things like that * double glazed windows * solar boosted hot water service - once again, for when you have selfish teenagers who, even in a drought, steal all the hot water. items we forgot 54Oct 08, 2008 9:22 am Items I now wish we had included in our house at build time (some which we are retro-fitting now). Granted not all are essentials but at least worthy of consideration !?
- 15A power outlet in workshop / garage and outside. (cant run anything but a small arc welder on standard 10A outlets ... also some other power tools, eg table saw, need 15A outlets) - dimmers on downlights - I would have never thought of this before but now that we have a newborn home he is fascinated by the lights and undimmed downlights are too intense to "stare" at (at least to me the new worrying father) - which way the pantry door swings, or what type of door you use here. In our case the door swings back onto usable shelf space (now accessible only by getting into the pantry and shutting the door). Meanwhile we have a service duct / void on the other side of the door, so if the door swung the other way it would be blocking only the void! - location of outdoor taps - somehow we failed to notice that our plans didnt have a tap at the rear of the house, only on both sides (and then towards the front of the house) - whirly birds in the roof - paying extra to get electrical cables fixed in the ceiling to allow easier later installation of ceiling insulation, (we have an anticon blanket under the roof but I also now want to add batts) - provision for laundry greywater collection - even if just have a covered hole in the laundry external wall to pass a greywater hose through from the washing machine so dont have to have the door open. - a secure / external door between the garage and the house, ie internal access. Rather than the lightweight non lockable internal door that you get as standard. - check windows noted as fixed glass and reconsider / reassess if you really want a window that cant be opened. - assess extra cost to have section of the ceiling timbers designed for attic loading - ie future attic conversion - second showerhead in ensuite - check your shower size and if it supports two showerheads I would advise to do it now when building even if dont think you would use it some items we did remember and I'm thankful: - sound insulation in internal walls (majority of walls at least) - thermal insulation batts to all external walls (make sure electrical cabling is designed for this) - lots and lots of powerpoints (all doubles) - the location of downpipes and how it will look - ceiling fans in bedrooms and outdoor entertaining area (alfresco / gazebo) - TV point and powerpoints in main bedroom times 2 - ie we have doubled up to allow us to swing the orientation of the bed in the room. In our case this was because we couldnt decide / agree at build time which way we were going to orientate the bed in the room! Now wish we had done the same in our living room. - lots of linen cupboards - wide openings to passage ways - I think standard is 900mm, go for 1200mm. Apart from day to day living you will also love it for moving furniture around! (not to mention less patching / repairs and/or pulling furniture apart) - width of garage - provision for greywater collection from showers, baths. We got separate sewerage lines run from our top floor so we can easily connect into greywater "later". minimal cost for separate lines, dont have to expend big dollars up front for a greywater system just make it easier / cheaper if you want to do it later. Re: Things you forget - summary page 32 56Oct 09, 2008 9:39 pm BlackRain haywgl MrT And if you're provisioning for PayTV, don't forget the phone cable that should be installed to the outlet as well as the coax cable (we did, but caught it just in time). Is this necessary to make the pay tv work or only if you want to order movies etc? The reason I ask is that we don't have a phone point next to our current Foxtel and it works fine...the only problem we have is if we want to order something through Main Event/Movies we have to ring up to customer service to do it rather than order it via our remote. I think you are right about the phone line being for ordering movies on In our previous rental home we had Foxtel but there was no phone point near where we had the TV connection so we were given a wireless connector to plug into the power point near the tv that had a phone line going from it to the set top box and another wireless connector in the kitchen hooked up to the phone line. Was a bit of a pain in the bum as it took up an extra power point in the kitchen when I would rather have had my kettle hooked up So I suppose it would be better to get the phone put in near the TV point just for convenience sake which is what I have done on our new place Just asked my brother about this as he works for foxtel, he says not only is the phone point for ordering movies, and doing interactive stuff, but they often, in the middle of the night do updates to software on the iq boxes and it is done via the phone line Re: Things you forget - summary page 32 57Oct 10, 2008 9:25 am We are in the final stage now, so still got a few things to go before we know everything we may have forgot, so far we have notice in the kitchen, our sink is on a bench which doesnt have a wall against it, so if a dish is to fall it falls on tiles! so should have had added something at the back of the sink to make sure that couldn't happened!
A good thing lve notice a lot of ppl do forget is outside powerpoints, so if you haven't done your electricals think of those! and was also told to remember conduit for outdoor lights, its something you should do before a driveway or path goes down, if you want outside lights later on, adding the conduit now will save you LOTS of money later (so im told!) Re: 58Oct 21, 2009 12:34 pm MICA Hi there all, I must say, we can add realms of points, but taking into consideration the following points: - your brand new home, - you paying the mortgage, - getting through the first winter, -etc, etc, etc, A MUST for all new homes is a Heater Point in the Bathroom!! You'll thank me for it once you move in! Hehe This is so true for me - All the things I am reading on this forum I wish I could afford to do but may have to be done later Kel Building in Mooroolbark! Building permit: 21.10.09 Site Start: 12.11.09 Slab 23.11.09 Frame completed 18.12.09 Roof completed 15.01.10 Lock up 05.03.10 Fixing : 30.04.10 Handover: 11.06.10 Blog: http://kelnryan.blogspot.com Re: Things you forget 59Oct 21, 2009 11:27 pm love all the suggestions so far ... keep em coming people ... we all need our houses PERFECT We're building The Albany 330E with Casa Design & Construction via National Builders Group See how we are going here: https://forum.homeone.com.au/viewtopic.php?f=31&t=32694 Re: Things you forget 60Oct 22, 2009 9:38 am Suggestions ! - data cabling GALORE ... we did like every room in the house... (multiple points in some rooms) - extra phone line for security system if you feel the need - the special cable for foxtel so we can connect easy at some point in the future. - organised the split system air con before building started.. so all our cables are now hidden inside the walls and dont require ugly pipes hiding cables everywhere Think about cross breezes etc when considering window positioning. For example our master bedroom.. standard was a window facing the east... we added another window on opposite side (west) so the breezes can now flow straight through.. its lovely ! and im so glad I did it ! If you are wanting just that bit of extra space.. but dont want to go nuts with extensions, consider pushing the walls out to the eaves (i.e. so you have no eaves). We did this with 2 sides of our master bedroom.. which made the bedroom and ensuite bigger Security lights out the back and the front Depends what you're current inclusions are, but we're not including wardrobes and will just use second hand ones until we can save later on to get them built. Also have a… 3 12456 A question. Im in Queensland and building a new home. We managed to reach practical completion 6 weeks ago but we haven't heard any date for handover yet. Who should we… 0 6281 Bought in Nov 21 at the height of the market (classic). Good area, atrocious floor plan. BUT has land out to the left-hand side that we can extend out on (see second… 0 9160 |
