Browse Forums Bathrooms and Laundry Re: Exhaust fans ducting into the ceiling 3Oct 05, 2013 11:57 am Today is under construction. Thank you for understanding. Re: Exhaust fans ducting into the ceiling 5Oct 05, 2013 5:05 pm Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Exhaust fans ducting into the ceiling 7Oct 06, 2013 6:06 am Today is under construction. Thank you for understanding. Re: Exhaust fans ducting into the ceiling 9Nov 02, 2013 10:22 am Today is under construction. Thank you for understanding. Re: Exhaust fans ducting into the ceiling 10Nov 02, 2013 1:46 pm Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Exhaust fans ducting into the ceiling 11Nov 10, 2013 2:26 pm Today is under construction. Thank you for understanding. Re: Exhaust fans ducting into the ceiling 14Dec 11, 2013 4:01 pm Today is under construction. Thank you for understanding. Re: Exhaust fans ducting into the ceiling 16Dec 29, 2013 12:20 pm elemist Something i've seen at a friends place was venting to the eaves. IE ducting the exhaust fans through the ceiling, then drilling through the eave and fitting a grate. Doesn't look the best - but would be cheaper than cutting through colorbond i would imagine - and really if it's down the dead side of the house where no one goes it doesn't have to look pretty. I've seen old houses with eaves that aren't solid at all, they're like an open grille all the way round. But I thought in newer houses when there's vents in the eaves its something to do with enabling air flow out a whirly bird, a way to make the whirly birds more efficient by increasing incoming air? That's what I read the purpose was anyway. Btw don't fit vents in eaves in older houses without checking for asbestos cos eaves is one of the places to specifically check. Re: Exhaust fans ducting into the ceiling 17Dec 30, 2013 3:12 pm The house isn't actually that old - just a self-build done on the cheap. Today is under construction. Thank you for understanding. Re: Exhaust fans ducting into the ceiling 18Dec 30, 2013 3:31 pm Sorry, the tv ads warning about working on old houses must be having an effect. That wasn't the focus of your original question. So I read the thread over and your followup question is this. ashilleong Finally got a quote for what we are after . $699, including appliances, for both bathrooms. Fair? Is that for the electrician to fit them, what brand/type, and with ducting, and what sort? Re: Exhaust fans ducting into the ceiling 19Jan 08, 2014 9:07 pm elemist Something i've seen at a friends place was venting to the eaves. IE ducting the exhaust fans through the ceiling, then drilling through the eave and fitting a grate. Doesn't look the best - but would be cheaper than cutting through colorbond i would imagine - and really if it's down the dead side of the house where no one goes it doesn't have to look pretty. Our eaves dip down, so you can't see the vents unless you happen to be walking under and looking up. It was going to be too expensive to duct through the roof, as although we are in suburban Sydney, we have a fire rating of BAL-FZ, and it would have to be a fire resistant vent. Re: Exhaust fans ducting into the ceiling 20Jan 23, 2014 2:18 pm Well- the electrician we chose was more expensive than the others, but would do the ducting. ...and then didn't. He installed the fans and decided not to do the ducting after all. He says there isn't enough room, although wasn't clear why, and will "take the ducting off the price of installation" which is great, except he wants to charge more than anyone else quoted for installation only. Freakin nightmare! Today is under construction. Thank you for understanding. My home office is hot with computer equipment running virtually 18 hours a day. When it gets unbearably warm I simply step out of my door into the living area which is… 0 5351 There may be answers here but can't find anything. I have a closed in veranda, four windows. North facing, just had sunblock blinds installed. A bit cooler (actually… 0 3890 Thank you @ashington Homes for your reply! They just got back to me and offered credit for me to just take it as is. It was a less than quotes I got from ceiling… 6 2071 |
