mirzSame size on hinges will cost much cheaper may be around $1200.
Here is a good thread with exact quoted price:
viewtopic.php?f=23&t=61395
Perfect, thanks Mirz,
I've emailed BC as well so fingers crossed as to when we get response
Sam
Browse Forums Building A New House Re: Porter Davis Upgrades and Costs 267Aug 21, 2013 5:03 pm Does anyone know how much PD will charge if we do not have an underground pit for electricity? I'm not sure as i'm only just building, but i specifically requested the fridge tap to be put on the side, not on the back of the wall to prevent this problem. That's what we originally requested too, but we changed it back after thinking about it bit more because for us the main concern is how far a tap would protrude from the wall. If we placed it on the side then we wouldn't be able to fit a wide fridge (remember most side by side fridges are about 1 meter) and it's ok to protrude a little for the doors to open. Re: Porter Davis Upgrades and Costs 268Aug 21, 2013 9:37 pm Hi Jackula, I don't know how accurate it is, but I was told if our underground wasn't done before the frames started to go up it was $1500 to access power... I don't know if that was a once off, or monthly or what - but that is what my BC said... Hope that helps. Re: Porter Davis Upgrades and Costs 269Aug 22, 2013 2:09 pm Thanks, I'm pretty sure it would be once off, because PD told us the additional charge will cover the cost of extra equipment to connect your house to power, we just didn't know what the charge actually was. Looks like this is a more viable way of getting power vs $20k+ for an underground pit. Re: Porter Davis Upgrades and Costs 270Aug 27, 2013 8:23 am good morning all, quick question. having my electrical appointments at hopetoun tomorrow. Building a single storey 29 square home. Downlights. Any opinions on options? 1. Get them through PD? i think they are approx 135 each 2. Have battens instead and change them post handover? no idea of costs associated 3. Do nothing and just have the single batten for each room in the middle and do downlights separately after. Again, no idea of costs. Help? Re: Porter Davis Upgrades and Costs 271Aug 27, 2013 8:43 am Hi hocm being single level means you can do any of the above really. If this is your first home and budget is an issue, you can always get down lights later. We had downlights put in downstairs because this is hard to do after the house is built and battens upstairs because we can get to it easily to do later if we want to. I like light fittings so I (we) decided to go with batterns because it gave us the flexibility to decide on the type of lighting in each room once we had thought about it a bit more or even lived in it and then we work out how much lighting we need for example if rooms are darker than we thought. I am also a fan of lamps. Just my opinion. Hope this helps Porter Davis Upgrades and Costs 272Oct 30, 2013 9:28 pm Just to bring this thread alive, currently PD is offering: 1. Free colour bond roof upgrade. 2. Free flooring pack. 3. Few double story houses with free alfresco. I'm not sure if you can have all three freebies in one home...... But still upgrades limitations to lifestyle ranges su**s big time. Re: Porter Davis Upgrades and Costs 273Nov 08, 2013 5:28 pm mirzThat heating upgrade for $14,758 sounds very expensive, or it's typo? So you ended up having three zoned for extra $864 in total? With 3 points each zone, can they be three bedrooms upstairs in one zone, and rest of upstairs second zone, and all downstairs third zone? Not a typo, the HX35i is a really powerful unit that has refrigerated cooling as well and requires 3 phase power. We have four zones in total, it comes standard with 2 zones and we got another 2 zones with an additional control. Yes, you can have zones anywhere, but any single zone must not split between floors. For our home, we have: - zone1 (upstairs) as master bedroom, master ensuite and bedroom 1 - zone2 (upstairs) as bedrooms 2, 3 and rumpus - zone3 (downstairs) as home theatre, powder, study - zone4 (downstairs) as dining, living, lounge very useful ![]() Re: Porter Davis Upgrades and Costs 274Nov 08, 2013 10:15 pm More electrical info. They offer different packages depending on your area and location so you will need to check what packages you are eligible for. We are getting Opticomm in Clyde North. Included in this list are: Sound and Entertainment Sonos Music System OpeNetworks Fibre Optic Estate - Pakenham Telstra Fibre Optic Estate CNT Corp Fibre Estate Places Victoria Fiber Optic Estate Pack - Riverswalk estate Opticomm Fibre-Optic NBN Wiring Home Networks Golf Club Estate Package - Sandhurst Push Control System InterCom SOUND & ENTERTAINMENT 5030225 INDOOR SURROUND SOUND SPEAKER PACK $1,288.00 Five Jamo In-Ceiling or In-Wall Speakers with five speaker cables and subwoofer cable (inc power point) pulled through wall access plate (position to be nominated) for connection to clients own Surround Sound music system (by others after handover). 5030226 TWO-SPEAKER PACK $435.00 Two Jamo In-Ceiling or in-wall Speakers (internal or external) with two speaker cables pulled through wall access plate (position to be nominated) for connection to clients own music system (by others after handover). *Outdoor speakers are ceiling only Note: The packages below are cabling only, and pricing does not include speakers, or installation of client's own hi-fi or home theatre equipment. Cables to be left behind plaster for future AV installer, (Plans can be supplied by Argus Operations department) 5030227 SPEAKER PRE WIRE PACK $180.00 Pre-wire only for future speakers. Includes 2x speaker cables (position to be nominated) run back to nominated location for connection to clients own music system (by others after handover). Argus is not responsible for location of cabling positions at time of handover due to building conditions outside of our control, cable plan can be emailed to owner with cable measurements if requested. 5030228 5.1 SURROUND SOUND PRE-WIRING $591.00 Pre-wire only for 5.1 surround sound, speaker cables (to be left in wall or ceiling cavity) and subwoofer cable (inc power point) pulled through wall mounted access plate at main entertainment only (position to be nominated) for connection to clients own home theatre system (by others after handover) - Argus is not responsible for location of cabling positions at time of handover due to building conditions outside of our control, cable plan can be emailed to owner with cable measurements if requested. 5030234 Pull speaker cabling through plaster - per 1 speaker point $40.00 5030229 PROJECTOR PRE-WIRING SINGLE STORY $341.00 Pre-wire only for projector (including HDMI,and single plug base), cables to run from nominated ceiling point to nominated home theatre system equipment location (max 8m of cable. Cabling left in ceiling cavity for future fit off by others after handover). 5030230 PROJECTOR PRE-WIRING DOUBLE STORY $462.00 Pre-wire only for projector (including HDMI, and single GPO with extra switch mounted on ceiling, client must specifify projector throw distance), cables to run from nominated ceiling point to nominated home theatre system equipment location (max 8m of cable. Cabling pulled through ceiling at specified location for future fit off by others after handover). 5030231 WALL MOUNTED TV PRE-WIRING $367.00 Pre-wire only for future wall mounted TV (inc HDMI, RG6 coaxial link, flush mount wall box inc GPO) cables to run from nominated TV location to nominated home theatre system equipment location (max 3m of cable) 5030235 HDMI cable pulled through plate at nominated height $100.00 5030232 FIBRE OPTIC STARRY CEILING $3,915.00 Fibre Optic Starry Ceiling comprising 250-strand 50 watt fibre optic kit, power in roof and wall switch. *Can only by installed to single storey section of homes. Manhole access required. 5030233 FIBRE OPTIC STARRY CEILING $6,677.00 Fibre Optic Starry Ceiling comprising 500-strand 50 watt fibre optic kit, power in roof and wall switch. *Can only by installed to single storey section of homes. Manhole access required. SONOS MUSIC SYSTEM 5030236 Sonos PLAY:3 Zoneplayer - BLACK or WHITE $419.00 Sonos PLAY:3 All-in-one wireless music system (no controller included). (please specify colour) 5030237 Sonos PLAY:5 Zoneplayer - BLACK or WHITE $599.00 Sonos PLAY:5 high-performance all-in-one wireless music system (no controller included). (please specify colour) 5030238 Zone of Sonos $799.00 Additional Sonos Zoneplayer 120 with integrated 50w amplifier 5030239 Zone of Sonos $549.00 Additional Sonos Zoneplayer 90 (connects to clients own amplifier) 5030240 Sonos ZoneBridge $79.00 Wireless bridge for fast and easy setup of Sonos system wirelessly. Note: All sonos equipment prices are supply only 5030241 Initial Installation Charge - one zone $230.00 5030242 Sonos Installation Charge - per extra zone $94.00 OPENETWORKS FIBRE OPTIC ESTATE 5030243 FIBRE ESTATE FOUR-PACK $3,066.00 "Data (Cat6 cable cat 5e mech), phone, TV, and Pay TV plate from one central location to 4 nominated locations. Slimline enclosure and single power point. (Four pack cannot be upgraded) * PACK DOES NOT INCLUDE UNDERGROUNDS. Includes external CTC Cabinet & GPO, links between WSC & CTC Cabinet and lodging of forms to OpeNetworks" 5030244 FIBRE ESTATE EIGHT-PACK $4,606.00 "Data (Cat6 cable cat 5e mech), phone, TV, and Pay TV plate from one central location to 8 nominated locations. Slimline enclosure and single power point. **Pack not upgradable *PACK DOES NOT INCLUDE UNDERGROUNDS. Includes external CTC Cabinet & GPO, links between WSC & CTC Cabinet and lodging of forms to OpeNetworks" OPTIONAL EXTRAS 5030245 One additional TV point $117.00 5030246 One additional Phone/Data point (Cat6 cable cat 5e mech) $117.00 5030247 Pay TV Point (Std) - inc 2 x RG6 $117.00 5030248 Pay TV Point (Foxtel , IQ HD)- inc 2 x RG6, 2 x Cat 6 $196.00 5030249 One additional multi-socket point to receive data, phone, TV and Pay TV from WSC. **Suitable for upgrade to 'Smart Community Eight-Pack' only. $291.00 5030250 Digital Quad modulator - distribute Cable TV and DVD signal from one location (position to be nominated) to all TV's in the home. PRICE TBA 5030251 Upgrade data mechs from cat5e to cat6 - per point $37.00 TELSTRA FIBRE OPTIC ESTATE 5030252 TELSTRA VELOCITY BASIC $1,240.00 Points run back to WSC in garage inc double gpo. 1 x 6mm earth to Telstra box on side of house, 1 x 32mm comms pipe from ONT to garage with draw string, 1 x Krone Bracket , 1 x TV distributor 2 TV Points 2 Phone Points 1 Data Point - (Cat6 cable cat 5e mech) all points are run back to WSC in garage, as per telstra velocity specifications * cannot be upgraded ** pack does not include undergrounds 5030253 TELSTRA VELOCITY ENTERTAINER $2,374.00 Points run back to WSC in garage inc double gpo. 1 x 6mm earth to Telstra box on side of house, 1 x 32mm comms pipe from ONT to garage with draw string, 1 x Krone Bracket , 1 x TV distributor 2 TV Points 2 Pay TV Points 2 Phone Points 2 Data Point - (Cat6 cable cat 5e mech) all points are run back to WSC in garage, as per telstra velocity specifications *can be upgraded to a total of 4 x tv, 4 x pay tv, 4 x phone, 4 x data - further upgrade requires inclusion of video hub ** pack does not include undergrounds 5030254 Upgrade to video hub & large WSC (to accommodate up to 8 x tv, 8 x pay tv, 8 x phone, 8 x data) *for entertainer option only ** does not include additional outlets $776.00 OPTIONAL EXTRAS 5030255 Testing of Points *max of 40 data points $159.00 5030256 One additional Phone/Data point (Cat6 cable cat 5e mech) $117.00 One additional TV point $117.00 5030257 Pay TV Point (Std) - inc 2 x RG6 $117.00 5030258 Pay TV Point (Foxtel , IQ HD)- inc 2 x RG6, 2 x Cat 6 $196.00 5030259 Digital Quad modulator - distribute Cable TV and DVD signal from one location (position to be nominated) to all TV's in the home. PRICE TBA 5030260 Upgrade data mechs from cat5e to cat6 - per point $37.00 5030261 Upgrade WSC $324.00 CNT CORP FIBRE ESTATE 5030262 CNT Corp FIBRE ESTATE PACKAGE $2,431.00 "Lead-in cables and 32mm conduit inc drawstring from Meter Box to Approved Multinet Enclosure in garage 1 Multinet Enclosure installation in garage as per specification 1 RJ45 Data Hub within Enclosure 1 Double GPO within Enclosure as required 2 x TV (with a data point on plate) 2 x Phone, 2 x Data (Cat6 cable cat 5e mech) * For Every TV point there must be a data point on the same plate **upgradable to 1 additional TV point, (this will then use one of the remaining 2 data points included in the pack, which leaves 1 data point for internal use), no further upgrades to this pack can be accomodated) 5030263 One additional Phone - (phones to be daisy chained, Cat6 cable cat 5e mech) $117.00 5030264 One additional TV $117.00 5030265 Upgrade data mechs from cat5e to cat6 - per point $37.00 5030266 Upgrade WSC $324.00 5030267 CNT Corp PROFESSIONAL FIBRE ESTATE PACKAGE $3,991.00 "Lead-in cables and 32mm conduit inc drawstring from Meter Box to Approved Multinet Enclosure in garage 1 Large WSC installation in garage as per specification 2 Patch Panels (angled), 16 port switch within Enclosure 1 Double GPO within Enclosure as required 4 x TV (with a data point on plate) 2 x Phone, 2 x Data (Cat6 cable cat 5e mech) * For Every TV point there must be a data point on the same plate **upgradable to max 8 TV & Data points outlets, 8 additional data outlets, 3 Phone points (daisy chained) no further upgrades to this pack can be accomodated)" 5030268 One additional Phone/Data point - (Cat6 cable cat 5e mech) $117.00 5030269 One additional TV & Data point $233.00 5030265 Upgrade data mechs from cat5e to cat6 - per point $37.00 PLACES VICTORIA FIBRE OPTIC ESTATE 5030270 RIVERWALK ESTATE $2,577.00 5 x Wall Plates with 2 points; (1 x Phone, 1 x Data (Cat6 cable cat 5e mech)) Installed into lounge room or Entertainment Area, Master, Bed 2, Bed 3 & Kitchen. Installation and termination of all cables to be fit off to FTTH cabinet (supplied by Places Victoria) patch Panel inc sep circuit with double gpo, earthing of enclosure to main switch board, mode 6 phone socket with filter, chrone disconnection block. Paper work lodged for certification. (maximum of 6 phone & 8 data, clients to contact Places Victoria for any variations) *Places Victoria Riverwalk current Fibre specifications do not cover TV 5030271 wall plate 2 point (1 x phone, 1 x data, only this configeration) $233.00 OPTICOMM FIBRE-OPTIC ESTATE 5030273 FIBRE ESTATE FOUR-PACK $2,072.40 Slimline Enclosure, Lead in cable for Opticomm fibre-optic from Meter Box to the Hub Double GPO for Optical Network Termination (ONT) Box 4 x Smart Wired Wall Outlets in total:- 4 x General Wall Outlets: 2 x Phone/Data (Cat6 cable cat 5e mech) & 2 x TV/Pay TV (RG6) * PACK DOES NOT INCLUDE UNDERGROUNDS. Maximum 4 multi socket outlets - further upgrade requires inclusion of video hub NBN WIRING, NBNCO 5030285 NBNCo Preparation Pack $397.98 Wiring for future NBNCo rollout - includes internal conduit with draw string, gpo *NBNCo to supply PCD, NTD & FWO after handover, phone & data points (not supplied) will need to run to this location to be able to integrate with the future system. Patch leads not supplied, undergrounds not included 5030286 NBNCo BASIC FIBRE PACK $970.00 Internal conduit with draw string, gpo, x 3 Phone or Data (Cat6 cable cat 5e mech)points, (enclosure not supplied) run to plates on wall in garage for patching to NBNCo supplied product *NBNCo to supply PCD, NTD & FWO after handover, phone & data points will need to run to this location to be able to integrate with the future system. Patch leads not supplied, under grounds not included 5030287 NBNCo BASIC FIBRE PACK WITH ENCLOSURE $1,144.00 Internal conduit with draw string, gpo, x 3 Phone or Data (Cat6 cable cat 5e mech) points, WSC on wall in garage for patching to NBNCo supplied product. Upgradable to max of 8 phone/data point total *NBNCo to supply PCD, NTD & FWO after handover, phone & data points will need to run to this location to be able to integrate with the future system. Patch leads not supplied, under grounds not included Note: The NTD supplied by NBNCo has 2 voice ports & 4 data - to increase data points an 8 port switch is required to increase to a max of 10 data points NBNCo does not support TV, TV cable to be run independent to NBNCo fibre pack 5030288 Upgrade data mechs from cat5e to cat6 - per point $37.00 5030289 Testing of Points *max of 30 data points $159.00 5030290 Upgrade WSC to allow for additional 8 port switch $495.00 5030291 8 port switch (Supply only) $206.00 5030292 Phone/Data Point - (Cat6 cable cat 5e mech) $106.00 HOME NETWORKS 5030293 NETWORK FOUR-PACK $1,034.00 Distribute data from one central location to 4 points, includes data points with sockets to 4 locations, patch leads and switch. 5030294 NETWORK EIGHT-PACK $1,585.00 Distribute data from one central location to 8 points, includes data points with sockets to 8 locations, patch leads and switch & router. 5030295 PROFESSIONAL NETWORK PACKAGE $4,633.58 Distribute from rack to 24 points, includes data points with sockets to 24 locations, 1 6RU data rack with intergrated fan, 24 port CAT6 patch panel, 1 gigabit Router & 24 port network switch OPTIONAL EXTRAS 5030296 Upgrade data mechs from cat5e to cat6 - per point $37.00 5030297 TV Digital Roof-Mounted Aerial - Leopold/Torquay/Mernda/Lara & Surrounding suburbs; inc 20 Foot mast Pole, VHF & UHF Antenna, booster $1,162.00 5030298 TV Digital Roof-Mounted Aerial - all other areas $360.00 5030299 TV Aerial Booster (for over 4 TV points) $106.00 5030300 TV Aerial Booster 6 Points & above - Video Hub $555.00 5030301 Cisco Linksys Wireless Router - 4 Port *Network setup not included, supply only $163.00 GOLF CLUB ESTATE PACKAGE 5030302 "SANDHURST ESTATE OR SANCTUARY LAKES ESTATE (includes both WSC & Alarm Components listed below)" $3,809.60 WSC Component Lead-in cables from Meter Box to WSC in garage 1 WSC (Wired Services Cabinet) installation in garage as per specification 1 RJ45 Data Hub within WSC 1 Double GPO within WSC as required 2 TV Points 3 Data/Phone point 1 Club phone point only (phone to be provided by others) Security Component 1 Crow Powerwave 16 Zone Security Panel within WSC 4 PIR detectors 1 PIR to cover WSC in garage 1 PIR to cover front entry 1 PIR to cover key pad 1 PIR to owner's choice 3 Door Reed Switches 1 to front entry 1 to laundry entry 1 to garage personal access door 2 Smoke Detectors run to secuirty panel (3 for doubles) 1 Smoke detector compliance module as per specifications 2 Panic duress buttons as per owner's choice 1 LCD Key Pad 1 External Siren & Strobe 1 Internal Sounder 5030303 SANDARRA / ESPERANCE ESTATE PACKAGE $1,565.52 WSC Component Lead-in cables from Meter Box to WSC in garage 1 WSC (Wired Services Cabinet) installation in garage as per specification 1 RJ45 Data Hub within WSC 1 Double GPO within WSC as required 3 Data/Phone point PUSH CONTROL SYSTEM 5030304 PUSH CONTROL SYSTEM $2,122.00 Push Control Box to control up to 4 devices (eg. TV, Amplifier, DVD Player, Media Centre) Installation, Commisioning and programing of x 1 Smart Device (iPad or iPhone) * iPad or iPhone not included 5030305 ADDITIONAL DEVICE PROGRAMMED - iPad or iPhone $128.00 * Requires data point at equipment location ** Internet must be availiable at time of installation INTERCOM 5030306 COLOUR VIDEO INTERCOM - DORANI $1,200.00 x 1 Dorani 7" Internal Colour Video Intercom Monitor with front door vandal proof colour camera and chime. Inc GPO 5030307 COLOUR VIDEO INTERCOM - DORANI $1,747.00 x 2 Dorani 7" Internal Colour Video Intercom Monitor with front door vandal proof colour camera and chime. Inc GPO 5030308 Install after handover in North & West suburbs $66.00 5030309 INTERCOM PRE-WIRE 1 STATION $471.00 Pre Cabling for future Intercom System, including cabling to front door camera location, and 1 x internal monitor location, inc gpo. **Pack does not include installation of existing intercom system. 5030310 INTERCOM PRE-WIRE 2 STATION $596.00 Pre Cabling for future Intercom System, including cabling to front door camera location, and 2 x internal monitor locations, gpo. **Pack does not include installation of existing intercom system. 5030311 Upgrade front door cabling to cable location for future intercom at front gate - specify termination location on façade $66.00 Thanks, very helpful Re: Porter Davis Upgrades and Costs 275Nov 08, 2013 10:48 pm One thing to note, there is no need to pay anything for NBN connection. whole NBN connection is free of charge and NBN tech will do it for you. NBN will trench, lay conduit, and do all the wiring, and connection to your garage for no charges. builders are charging basic NBN connection pack around $1000-$1200 is absolutely unnecessary. Re: Porter Davis Upgrades and Costs 276Nov 08, 2013 11:47 pm inglewoodSo... here goes: We are building the Drysdale 30 from the Lifestyle Range Prices as at April 2013 $2,200 --- Gable Facade $16,018 --- Slab upgrade (H2 including screw piles) $2,510 --- Double glazing to Dining and Living (for 6 star energy rating due to house position) $5,205 --- Bushfire Assessment Levy Garage $4,166 --- 2000mm extension to the width of the garage $1,124 --- 6000mm length internal plaster wall to garage $558 --- 1800mm high x 600mm wide aluminium awning MC 1 Lite window to the garage front external wall $1,552 --- appox 4000mm long store cupboards incl 2No. Corinthian Quickslide RMDF2 units (4 flush doors in total) Windows $192 --- Spotswood glazing to windows (ens and bath) $121 --- 1200mm hight x 2400mm wide aluminium sliding windows to bedrooms 2, 3 and 4 in lieu of standard 700mm high x 2400mm wide sliding windows Doors $388 --- 2040mm high flush panel groved cavity sliding door in lieu of standard opening $190 --- 2040mm high flush panel hinged and latched door in lieu of standard opening $57 --- 2040mm high Corinthian Rockport 5 panel door in lieu of standard flush panel door $3.50 --- Passage set with privacy adapter in lieu of standard Roofing $608 --- Colourbond downpipes in lieu of zincalume $4,399 --- Colourbond roofing to the house and garage in lieu of standard Plaster $165 --- Shower niche 425mm high x 425mm wide $330 --- Shower niche 325mm high x 1025mm wide $175 --- 220mm bulk head above kitchen overhead cabinets Cabinets $306 --- Over fridge cabinet option one $283 --- Up to 1000mm wide 3 drawer pot drawer unit in lieu of standard base cabinet doors $189 --- Additional bank of 300mm to 450mm wide drawers to ensuite vanity in lieu of standard laminate cabinet door $175 --- Extend Laminate benchtop to the laundry Kitchen Upgrades $185 --- Mark up and re-installation of rangehood after splashback is installed $139 --- Fireproofing to glass splashback $1,107 --- Low iron glass splashback up to full height and behind rangehood in lieu of standard $1,575 --- Category 1 Caesar Stone 900mm wide x 900mm high Waterfall end panels to kitchen island bench $201 --- Blanco Niagra U2 Double Bowl Undermount Sink in lieu of standard $125 --- Capped cold water point for fridge Ensuite and Bathroom $121 --- Nuova 300mm straight wall outlet to spa bath $40 --- Pulsar 5 function shower on rail to bathroom shower in lieu of standard $36 --- Raymor Torino wall mixer to shower in lieu of standard $36 --- Raymor Torino pillar wall mixer to bath in lieu of standard $31 --- Raymor Torino pillar mixer in lieu of standard $1,802 --- Decina Corner Spa Traditional 1295mm $402 --- Upgrade above spa to Classic $79 --- Stainless Steel laundry trough in lieu of standard $34 --- Raymore Andorra toilet suite in lieu of standard $226 --- 1200mm x 900mm shower to Ensuite in lieu of standard $92 --- Extend mirror over the bath in bathroom Heating $1386 --- Heating upgrade HX30i in lieu of standard $154 --- Additional heating point Other items we obtained pricing for: $716 --- Pantry Cabinet option 1 including 32mm thick laminate bench in lieu of standard pantry layout $2609 --- 1200mm x 900mm Frameless shower screen $716 in lieu of standard semi frameless $2512 --- 900mm x 900mm Frameless shower screen $716 in lieu of standard semi frameless $6904 --- Laminex Colourtech finish upgrade to Kitchen cabinets (including overheads) in lieu of standard finish $125 --- Additional external tap Other things to consider: We are not upgrading any of the handles for the cabinets. We will do that after handover. Ebay is by far cheaper than PD (I'm considering ordering some from the US even with $$$ postage it will be cheaper than the upgrades PD is offering and there are some really really nice ones overseas) - if you go this route, then be sure to measure the handles - or just don't have them fitted and do it all after handover - IKEA sell a template for measuring handle placement. We are having a power point put inside each of the vanities - handy for chargeable toothbrushes and shavers... gets them off the bench. I don't have the costs for the electrical items on me atm, but they were the same as others already on here. Hope it helps! Many thanks Re: Porter Davis Upgrades and Costs 279Nov 11, 2013 8:04 pm Category 5 and also slim bricks would cost around $8k (in my opinion). For 48 sq house it would be around 20,000 bricks. Did you check Daniel Robertson hawthorn or Cambridge blends bricks? They look pretty a awesome too but not sure if PD builds with Daniel Robertson bricks. Re: Porter Davis Upgrades and Costs 280Nov 11, 2013 8:06 pm We are building Waldorf 48, anyone know the cost of upgrade to marble island benchtop ( from essastone) ? Thanks I don't think PD gives you option to marble benchtop upgrade. It would be cheaper to take credit back and organize through a stone mason post handover. Thank you for your response Simeon. I really appreciate your thoughts. Yes that makes sense. Thankfully my renovation is fairly straight forward since it involves the… 4 37836 We do around 10 demolitions a year and we went through so many companies who all do this as their standard practice until we found 2 who are ethical and we now split the… 11 10944 Old Home Restoration / Renovation Hi everyone, Dilemma going on. We are looking at buying an older house, one of the old commission/defence force homes, built in Ipswich QLD in about the 70's. So of… 0 13749 |
