Browse Forums Bathrooms and Laundry Re: Anyone tried Aussie Drain Mate/Grate Seal/Dekfit Grate M 3Aug 16, 2013 10:07 am All floor wastes should have an S or P-trap fitted as standard ( correct me here any plumbers reading this ) and I'm pretty sure it is common as per Australian Standard AS 3500 for that very reason. The sewer pipes are laid prior to the slab being poured and are basically in the soil under the slab. Stewie Re: Anyone tried Aussie Drain Mate/Grate Seal/Dekfit Grate M 4Aug 30, 2013 12:40 pm Hi John34, After we moved into our new house we noticed an awful smell coming from the floor waste in our laundry - turns out that when they were plumbing in the drainage before the slab was poured they neglected to put an S trap in that room.... Whoops. We bought a drain mate and problem solved. One small drawback is that the waste grill doesn't sit flush with the rest of the waste as its raised a couple of mil.... But we can live with that much more comfortably than the smell. Owner Building on 1800sqm Sanity Intact so far Locked up March 2012 Re: Anyone tried Aussie Drain Mate/Grate Seal/Dekfit Grate M 5Jun 06, 2022 10:35 am I have, it is complete crap. Gets mould and gunk on it within a week and jams open. Any hair in it and again jams open. It is the most useless thing ever invented unless you want to clean it verey day. Re: Anyone tried Aussie Drain Mate/Grate Seal/Dekfit Grate M 7Jun 06, 2022 7:56 pm Hi Pulse, sorry mate my reply was to the questiuon about drain mate. Drain mate is a plastic flap that is meant to keep out the stink . It is not a P or S trap but a mechanical seal. It is crap and doesnt work. I wish my are shole plumma put in a trap but he was ill equipped in the mental faculty department or dodge ee or both. I think about the cant of a plumma every day and how he far qed my property. Re: Anyone tried Aussie Drain Mate/Grate Seal/Dekfit Grate M 8Jun 07, 2022 9:57 am Pulse The floor waste is charged by a bath or basin, if they go dry they will let in sewer gas, common issue in a new build. If they are connected properly they don't go dry here Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Anyone tried Aussie Drain Mate/Grate Seal/Dekfit Grate M 9Jun 07, 2022 10:00 am howy I wish my are shole plumma put in a trap but he was ill equipped in the mental faculty department or dodge ee or both. I think about the cant of a plumma every day and how he far qed my property. That pluma would be on the nose every day (sadly no humour for you) Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Had a new driveway installed with a 6 metre long 150 x 150 channel drain and have since found out it has 4cm of water sitting at the bottom below the side pipe… 0 4856 I need to replace the worn mohair seal on my sliding window, but I can't get access to the end to slide the old one out & push the new one in. I could probably rip the old… 0 5688 4 15111 |
