Browse Forums Building A New House Re: Handover checklist - what's on your list? 2Aug 06, 2013 12:46 pm It's started! http://nickleglencastle.blogspot.com.au Re: Handover checklist - what's on your list? 4Aug 06, 2013 1:27 pm Build thread: viewtopic.php?f=31&t=65498 Deposit 17/02/13 Contract 12/04 Slab 17/05 Roof 06/06 Bricks, Lockup and Fixing 04/07 PCI 22/08 Handover 29/08 Moved in 07/09! Re: Handover checklist - what's on your list? 6Aug 06, 2013 1:54 pm Build thread: viewtopic.php?f=31&t=65498 Deposit 17/02/13 Contract 12/04 Slab 17/05 Roof 06/06 Bricks, Lockup and Fixing 04/07 PCI 22/08 Handover 29/08 Moved in 07/09! Re: Handover checklist - what's on your list? 8Aug 06, 2013 8:21 pm The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Handover checklist - what's on your list? 10Aug 06, 2013 11:06 pm Slab – 31 Oct 2012 Frame - 15 Nov 2012 Bricks – 26 Nov 2012 Roof - 14 Jan 2013 Lock Up- 11 Feb 2013 PCI- 23rd May 2013 Settlement - 7th June 2013 Re: Handover checklist - what's on your list? 12Aug 08, 2013 10:18 pm ![]() ![]() I think I saw on one post that painters are supposed to paint the top & bottom of doors, is this correct? If so, my doors have already been hung and I don't see how our painter will be painting the bottom. When you do your final inspection, have a box of little red dot stickers so you can go around and stick it on things that need to be replaced/repaired/looked at. My handover isn't for another 2 months, I imagine but I'm trying to be prepared. Anyone who has had their handover and found issues afterwards, your input would be more than appreciated. Actually it is sealing the tops and bottoms of wet area doors. We have settled on our house and will be getting our wet area doors sealed come the maintanence inspection period. I will get painters to remove, seal and the reattach my doors if necessary. I can't tell you how important it is to get wet area doors sealed properly. At our last house this was not done and the bottom of our bathroom door got wet, resulting I the bottom of the door expanding and warping. Some additional things to add to Hamilton's list include: Check around the whole perimeter of your bath tub to make sure it is fully sealed (ours wasn't). Take off your shoes and step along the entrance to all rooms that have carpet. I pricked my heal on a nail that was sticking up through the carpet. My SS made carpenters go back to hammer down all nails in room entrances that had carpet. Check that carpet has been anchored down properly. Our carpenters cut out a piece if carpet and literally plonked it in a wardrobe and left it like that, without anchoring it down ![]() Check water pressure by turning on a number of taps/showers at the same time. Bring a microfibre cloth to wipe down glass and mirror surfaces. This will make scratches more noticeable. We had a mirror in a robe door replaced and the full glass panel in our laundry door replaced due to scratches. SS was not happy as the glass in the laundry made up a major part of the door and was not only scratched in one area, but a number of areas.... Check for chips in tiles. Obviously check walls, ceilings, skirting and cornices for any scratches, imperfections. Rule of thumb is if you find something up close and can still see it from 2 m away then your builder is required to rectify the imperfection. Your SS should have a roll of painters tape on hand to mark all your walls, ceiling etc as issues are found. I do recommend getting an independent inspector through to look. They are qualified to pick up more serious issues, like things that would actually breach BCA standards, plus other things like paint and plaster issues. How will we know if they're sealed or not? I think we will look into an independent inspector, just for peace of mind. Re: Handover checklist - what's on your list? 13Nov 16, 2015 6:31 pm This is how it is... Top and bottom of all doors must now be painted...not just wet areas or entry doors If you use your own sticky red dots and they are pushed flat then the builder may not remove them as they could cause damage or mark the walls. Your problem, not the builders. Plus use removable dots, not permanent. Better still get the green safe removal roll of tape from Bunnings for about $1.50 roll. The sharp metal on your carpet edge is called...smoothedge and this has little metal triangles with points that hold the carpet in place. If you hammer these flat you will never get the carpet up in that area. plus is not recommended by carpet layers to do this. The "plonked" piece of carpet in your robes( except the walk in robe) is how all builders do it. This is never held in place or has an underlay but is known as loose layed. Standard practice in building industry When viewing paint....you must be 1.5 m away from the wall. 90 degrees to the wall and in natural light. You can not view paint on an angle as things like "glancing light" comes into play Scratches on glass....must be 2m from glass but there can be 3only 10mm scratches and this is within guidlines. Everything in your house has standards and tolerances so there is no such thing as perfect. hope this helps yes it does, you've just not understood it. theres a difference. 4 6203 Your house should come in "as new" condition. It should be clean, and without stains 1 5124 Hi Need to read your contract about when final payment is received. Clearly outlines what happens. In vic, known defects or incomplete work must be completed before… 3 1852 |
