Browse Forums Eco Living Re: Rainwater Harvesting Wet System Questions 2Jul 02, 2013 2:03 am 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Rainwater Harvesting Wet System Questions 4Jul 03, 2013 12:30 am 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Rainwater Harvesting Wet System Questions 6Jul 05, 2013 4:03 am 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Rainwater Harvesting Wet System Questions 10Jul 06, 2013 4:35 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Rainwater Harvesting Wet System Questions 11Jul 06, 2013 4:39 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Rainwater Harvesting Wet System Questions 13Jul 06, 2013 7:48 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Rainwater Harvesting Wet System Questions 15Jul 07, 2013 2:32 am 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Rainwater Harvesting Wet System Questions 16Jul 07, 2013 9:50 am Thanks. I'll do some drawings & see how it looks. Are the placement of the down pipes adequate & i have read that extra drainage would be helpful at the high points? When it comes to filtering is a good twin element system enough or is a UV steriliser an ideal addition? Only ever bothered with a filter before but would rather do it right once! Re: Rainwater Harvesting Wet System Questions 17Jul 07, 2013 4:51 pm Hi David, I don't have anything to do with filters and so I am not the best persons to give advice but I can offer some generalised info. The biggest mistake people make is having the pump's draw outlet fitted very low on the tank. The bottom layers of water are known as the anaerobic zone, the word meaning deprived of oxygen. When organic matter breaks down, oxygen is taken from the water. This is particularly bad when the process occurs in the wet system pipes because there is no air/water interface, unlike the water in the tank that can breathe. If the pump's draw outlet is fitted only 50 mm above the bottom of the tank at its lowest point as many are, then the pump will obviously draw the very worst quality water and vacuum the immediate sediment layer. Even when the water is not for potable use, it is still a bad set up as who wants to wash their clothes in poor quality water or have dirty toilet cisterns. The best quality water is found in the upper layers and it is ok to fit a very low outlet if you have a device like the one I have linked below that draws from the best quality water in the tank. You coulld also have one made up for 1/3 of the cost. http://www.crystalclearwater.com.au/waterboy/ The other thing that you could look at is a TankVac as your wet system will deliver much more water during heavy rain than a 90 mm overflow can handle. The TankVac extracts the worst quality water and sediment from the bottom of the tank rather than the best water from the top. It overflows through an 80 mm DWV pipe at 9 lps after a delayed start that is necessary to initiate the syphonic action. You will need to check as to whether the tank's design is suitable for the system as some current tanks are very poorly designed with little mitigation. http://www.youtube.com/watch?v=e1_B9WITe94 It is a New Zealand invention but the Australian contact (Neale) can be Emailed at: namcpheeplumbing@hotmail.com I am told that an Australian website is coming soon. It is always best to concentrate on delivering good quality water to the tank and if you do this, the filters will have an easy life. Having a settling tank system is a huge benefit. Leaf diverters that don't trap and then allow solid bird droppings to wash through are of more benefit than first flush diverters as they operate throughout the entire rain event. A lot of people have a 10 micron filter plus a carbon filter but an additional UV filter is often used. If you have overhanging trees with a possum population, then a good filtration system is vital as possums host Giardia and Cryptosporidium. These are protozoan parasites that can infect the digestive tract of humans. You could also look at a filtering system for the kitchen only and you also have to consider the effect on water pressure if all of the water is filtered. The Alternative Technology Association (ATA) forums would be a good place to ask for advice on filters. Rainwater is also naturally acidic and this will react with copper pipe. If you put limestone chips in a meshed nylon bag into the tank, this will alter the ph. The chips will build up a protective covering as they disolve and so you will need to take the bag out every 6 months or so and break them again. Just tether a small float to the bag so that you can retrieve it. DOWNPIPES Few houses have well designed roof drainage and display homes are a glaring example. When inspectors were commissioned by the Dept of Fair Trading Review Advisory Committee to randomly inspect display homes during the recent NSW inquiry into high fronted guttering and gutter compliance, of the 35 display homes inspected, only one was found to be compliant! You can access the report on the link I previously posted. Most overflows, unless the gutter is blocked with debris, occur away from the downpipe due to most downpipes being plumbed at the end of the walls for aesthetics, leaving the greater roof area the furthest distance from the downpipes. If you call a plumber, the first thing that they usually say is "you need a bigger downpipe" but that is usually not the solution when the overflow is happening 8-10 metres from the nearest downpipe. The device I linked offers a neat solution at very low cost (usually less than $30 for the items plus all fittings). If you want to try one, I will send you one FOC. Just PM me. You will need a 32 mm metal hole saw. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Rainwater Harvesting Wet System Questions 18Jul 08, 2013 12:07 am Once again, thanks SaveH20. So pipework would end up something like this? http://imageshack.us/photo/my-images/443/7mc4.jpg/ Re: Rainwater Harvesting Wet System Questions 19Jul 09, 2013 4:36 am Hi David, I had thought that running downpipes 1 & 2 separate would have used less pipe but the diagram shows a lot of pipe used to harvest downpipes 3-6 whereas I had envisioned a single pipe following the house perimeter. Obviously I can't see the property but if it is more straight forward to run downpipes 1-3 together, then that is what you obviously have to do. I didn't have time yesterday to get a cost comparison on the 2.5 mm walled 90 mm stormwater pipe. The normal 90 mm thin walled pipe is very weak but most plumbers use it for wet systems, mainly because it is cheap and they have no pride in their work. The better plumbers use DWV pipe. If you are on Bay of Biscay, then I wouldn't use the flimsy stuff. Re my earlier suggestion to initially run some 50 mm pipe, the problem is that I don't know the approximate roof areas that downpipes 3 & 4 harvest. There would normally be a high point at the valley near downpipe 4 and if there is, then I wouldn't run a 50 mm pipe between 3 & 2 as downpipe 3 will be harvesting a large roof area. There would most probably also be a high point between downpipes 4 & 6 near the wall separating living 2 & bedroom 2. If there is, then downpipe 4 is also harvesting a fairly large roof area due to the additional pergola roof area. It would be ok if there was more available head but 300 mm head on a long run during a major storm off a decent roof area could overtax a 50 mm pipe. The Gutter Pumpers that you have drawn are fitted at a valley. Valleys attract leaves and they flow down the valley en mass. The Gutter Pumper only generates a vacuum once the water is more than 20 mm deep and this means that a high point along a straight length of gutter is flushed prior to the vacuum starting. It's normal high flow rate also means that it operates with frequent vacuum breaks. When this happens, the suction stops and any debris washes past due to the turbulence during heavy rain. Valleys can be a problem however as debris can often 'raft' down. I recommend that you also fit some gutter guard to these areas. The Fielders Watergate is a good zinc mesh that is easy to DIY and comes in a 8 X 1.25 metre pack that costs about $40. Bunnings have it in their garden section. The long run to downpipe 6 is of no consequence as the G-P head is calculated from the gutter. The ID of 20 mm class 12 pressure pipe is 23.7 mm. You will need this figure for the calculator. Add about 25% to the pipe length as a fittings allowance if you don't know the fitting's friction losses. Do you have slotted gutters? If so, the overflows at the valley could be caused by generated hydraulic jumps during heavy rain causing the slots to overflow. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Rainwater Harvesting Wet System Questions 20Jul 09, 2013 11:41 am Pretty much no leaves get into our gutter, mainly dirt & dust over summer. No the gutters are not slotted. Gutterpumpers preferably in the high spot mid way between runs? I will investigate availability of thick walled 90mm stormwater & see if decent fittings are available. Most I've seen are just as thin as the pipe these days! There is a whole lot more to know than just the answers you seek but they are a good start. Overflow outlets have a mosquito proof mesh. These… 3 8655 Once you know the basics, the rest is easy. Read my post in the thread linked below. viewtopic.php?p=1919271#p1919271 2 19880 Grate, thank you! RexChan if thats the reason i could sleep well without thinking about additional cost. But 1st i'll need to read about NRV cleaning/replaing stuff. I… 7 31467 |
