Browse Forums Building A New House Re: Avonlee Henley Brook Perth 2126May 28, 2013 1:22 am Eeep, looks like Constable isn't listed as yet. I checked random addresses in Simony and all come up fine though. How odd that a couple of streets are available, but not others. I dont know the street numbers of Cob road to check. Well, I'm at 26 Cob Road and the map shows coverage up to Constable Street. Not sure anything past that would be available yet. Re: Avonlee Henley Brook Perth 2127May 28, 2013 10:52 am Ozherbie is there someone at your premises who has sworn their allegiance to the Horde? Oct 10 - Council Approval Oct 23 - Site scrape Oct 29 - Footings and Prelay OCT 30 - Slabbed Nov 6 - Bricks Delivered Nov 13 - Brickwork started Re: Avonlee Henley Brook Perth 2128May 28, 2013 11:04 am Got some more information back about addresses. Looks like their portal has been updated with the addresses. I feel pretty bad about shooting my mouth off, but Daed call up an ISP and make an enquiry about getting an install. give them this number and confirm its your address LOC000135364473 Re: Avonlee Henley Brook Perth 2129May 28, 2013 11:20 am Wow Bleh i think it worked! ? I am on phone with iinet now and placing the order, the LOC ID number worked and he says its serviceable!!! Woo dont want to get too excited but i think its happening haha. Thanks a tonne, will confirm once order has cleared and a installation date set Oct 10 - Council Approval Oct 23 - Site scrape Oct 29 - Footings and Prelay OCT 30 - Slabbed Nov 6 - Bricks Delivered Nov 13 - Brickwork started Re: Avonlee Henley Brook Perth 2130May 28, 2013 11:35 am See! I finally deliver... Hope its soon, I went out to my place last night and the Optical light on the NTD is on, which to me means the fibre in the street is lit up and should be good to rock out. Re: Avonlee Henley Brook Perth 2131May 28, 2013 11:38 am THanks - I got an install date from iinet for the 11th of June, we dont have an NBN box yet though so not sure how that works... Oct 10 - Council Approval Oct 23 - Site scrape Oct 29 - Footings and Prelay OCT 30 - Slabbed Nov 6 - Bricks Delivered Nov 13 - Brickwork started Re: Avonlee Henley Brook Perth 2132May 28, 2013 11:40 am Thats not too bad, pretty standard. So on the 11th is when they come out and do all the installation of the gear. Something by the meter box, and if you have smart wiring the box should go next to that. Re: Avonlee Henley Brook Perth 2133May 28, 2013 11:43 am Is it necessary for us to have the NBN box installed before iinet can do their thing? The guy I spoke to on the phone was very helpful but unfortunately wasnt too knowledgable on the technical details, sorry to pick your brains haha Oct 10 - Council Approval Oct 23 - Site scrape Oct 29 - Footings and Prelay OCT 30 - Slabbed Nov 6 - Bricks Delivered Nov 13 - Brickwork started Re: Avonlee Henley Brook Perth 2134May 28, 2013 11:51 am Nope, it goes hand in hand actually. So NBN wont do anything unless and ISP place an order. Which you now have. 1) Order by iiNet, tells the NBN to get out there and do the install. Drilling, pulling the fibre through conduit etc. 2) At the same time, they will setup an account for you and once the NBN has done their bit on the 11th, they will turn it on and start billing from that date. Sit back and wait but have a think about getting everything ready for when the internet arrives. For example we spent $4000 on smart wiring but that doesnt include a $80 switch to make every data port in the house connected to the internet. Did you have data/Ethernet ports in your house already? Re: Avonlee Henley Brook Perth 2135May 28, 2013 11:52 am bleh24, can I uses the same number as Daedalus. Or do I need a different one? 10 constable street? Re: Avonlee Henley Brook Perth 2136May 28, 2013 11:58 am Oh thanks for the explanation, really appreciate your help. I dont have any data points in the house at the moment, but i have plenty of conduit which i will run some cat6e through. i only want 4 points in the house really. i am assuming these points can be plugged straight into my router Oct 10 - Council Approval Oct 23 - Site scrape Oct 29 - Footings and Prelay OCT 30 - Slabbed Nov 6 - Bricks Delivered Nov 13 - Brickwork started Re: Avonlee Henley Brook Perth 2138May 28, 2013 12:03 pm DaedalusOh thanks for the explanation, really appreciate your help. I dont have any data points in the house at the moment, but i have plenty of conduit which i will run some cat6e through. i only want 4 points in the house really. i am assuming these points can be plugged straight into my router Yup its true, remember. You will need to connect the router to the NBN box, so one of the sockets on the router will be in use by that, so with most routers that would leave you with 3 usable sockets. Have a think about where the NBN box will go, as once its installed its there and cant be moved. This is the place where the router will go as well. Re: Avonlee Henley Brook Perth 2139May 28, 2013 12:04 pm Dargonk, yours will be LOC000135364867, I just wanted to be sure it worked on one. Thanks for that. Time to call iinet At similar stage, seems like all builders these days try to make some hidden money from site costs. Will know more as it proceeds. Try out maximising your initial costs… 1 29517 Hi mate, we’re going to be another couple of years before we end up building as decided to wait and travels around Oz in our caravan, so sorry can’t you really help… 11 104203 Wow thank you so much for all the effort you put in to this that's amazing. I just need to be careful how I name/lay out the rooms due to developer requirements - one… 9 28376 |
