Browse Forums Home Finance Re: When does the deposit become due ? 2Jun 17, 2013 4:51 pm Depending on what your deposit is and LVR, you might have to fork out at both stages. When you buy land, you will need a deposit when buying that and then a loan for the remainder. Then when you build, the builder will ask for some money upfront to do some initial work. Any remaining deposit will then be put towards the build at the first stage of construction of the additional loan (lenders will want your contribution first before they lend out). Cheers, Tom Have some black tiles in our bathroom on one feature wall laid on top of the waterproofing. What I think is efflorescence or white chalky looking grout has turned the… 0 2673 i had the my concreters concrete right up to the fence. I have pits all along my path, so the water tends to drain away from the house and into the pits. There's only one… 7 13450 Depends how much direct sun it gets. Is there any shading (eaves or trees)? If the sun hits a window directly it doesn't matter too much if it's double or single… 1 13059 |
