Browse Forums Building Standards; Getting It Right! 1 Dec 07, 2015 10:13 am Hey, anyone else out there using Loongana Limestone? I've noticed some yellowish/green staining on our bricks and its in our alfresco area so not exactly in a spot it won't be seen. What is it and will it clean off? Should I write to builders? I'm conserned that where it is will look awful if it won't clean up. Thanks! Photo attached. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Brick stains 2Dec 07, 2015 5:45 pm Just been reassured that it gets washed off. Apparently it's very common on the lighter bricks. phew!! Hi everyone, Have just put a shower in the laundry and after only using it 2-3 times have noticed staining on the grout. The tiles were glued onto a concrete wall after… 0 5833 Have look at your house plans and you will probably find that brick articulation joint has been missed. Maximum allowable spacing is 6M or 5.5M for a wall with window… 17 21313 If what you describe is correct then the brick wall has been dry lined with villa board. That basically means that the villa board is glued to the brick wall with… 3 8854 |
