Browse Forums Heating, Cooling & Insulation 1 Jan 28, 2010 3:35 pm Built the Coral Homes Hamilton 252 - moved in 20/10/2010 and loving it!! https://forum.homeone.com.au/viewtopic.php?t=27215 Re: How is this price for a Daikin Inverter? 3Jan 29, 2010 12:40 pm ~Nic~ ...so does this sound reasonable... Sounds fine to me... but as mentioned get the exact model number because those numbers are wrong... The 18kW cooling unit is rated 20kW heating and the 20kW cooling is rated 22kW heating, so clearly there's some confusion... Also I wouldn't be too worried about getting an inverter... the 20kW hybrid is a cracking bit of kit and $2k cheaper than the 20kW inverter... it'll take a very long time before you burn that in extra electricity... Wow I hadn't realised things had gotten that pricey in just a couple of years since I built, that is crazy with how much land is now costing if you aren't lucky enough to… 3 7525 Hi, you've probably already resolved this, however, Commbank will probably pay the funds to you after you send evidence the work is done regardless the change in the quotes. 1 35956 Just to makea point about this, an approach that some people have found sucessful in negotiating these rises down, Is to provide some workings to the builder, specifying… 4 82228 |
