Browse Forums General Discussion 1 Mar 25, 2024 12:17 am Hey guys I'm thinking of installing a french drain, but my soil is clay. Water has been leaking into my room through a crack in the foundation slab after this heavy rain. I've been looking at waterproofing the foundation but I don't think I have the technical skill to pull it off. I feel I can change the pvc down spout/ elbow connection. But the side of the house is not properly draining the soil effectively. Maybe I should airate the soil or amend it. Make a french drain down the fence line. I'm not confident enough to dig around the foundation of the house, but water leaks into my rain after heavy rain, I had a huge puddle Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Drainage 2Mar 28, 2024 9:59 pm You can use a better version of a French drain called a cut off drain along your fence line and run a plastic membrane over the ground between the house and the drain pipe and will create good drainage. Re: Drainage 3Mar 29, 2024 7:42 am ![]() "use a better version of a French drain called a cut off drain" That's the one, it's similar just dig the trench and the line the trench with some geotextile fabric and layer with some coarse aggregate. Place a perforated pipe on top of the aggregate. Fill up the trench with more aggregate and make sure it is compact (Careful not to crush the pipe!) HTH Regards -= Are you still using a notebook or spreadsheet to keep track of your customers and appointments? You need Simple Time Planner - Free Appointment Software =- I would find out how deep your clay base is and depending on the depth install a cut off drain which is more than a normal agi drain. Where the neighbouring walls is… 2 3642 13 7555 ![]() Building Standards; Getting It Right! It's all good. You can get both wye piece and the coupling with or without thread. The cost difference is negligible and means the plumber only has to carry the single… 1 5672 |
