House build over old underground pool
Im looking at some sectioned off land where an underground pool used to be. The owners told me it was leaking and was beyond repair so they threw in tonnes of materials they didn’t need anymore like furniture, wood and bricks that otherwise would have gone to the tip. Then the rest filled with dirt. Id like to build a house on this bit of land but i am concerned about potential risks for the build.
Does anyone have any advice on how to proceed or whether it just isn’t possible? I don’t want to purchase if I cant build on it.
Thank you
If you want to build on that spot, you'll need to remove the dirt, debris and the pool and then properly fill and compact and an engineer sign-off on it.
You have no idea what they put in there (furniture???) and how it would stand up to the weight of a house.
Hell no.
They sectioned off and are selling a part of their back yard.
I think they used the pool as a quick way to get rid of their rubbish instead of taking it to the tip and to save money since they didn’t want the pool anymore.
Probably going to cost me a lot to dig it up and fill it in properly. Not sure how much out of picket ill be on that.
Hi
Thank you
Thank you
Don't even consider it
If the fill is manageable, the rest is easier priced-If it went further I would look at using the pre-excavated, temporarily supported hole in the ground to construct a basement area. Better than backfilling and adds value.
Course, there is a strong possibility in a few years’ time you will be cursing yourself for thinking buying a landfill and building a house on it was ever a sane idea….
The second issue with piers is that if the fill is left, there is the potential for future gas generation. Subfloor venting might be needed but designed on what and DA approval might be tricky.
I'd say all the fill needs to go.
Hi, I'm clearing the tiles from our horrid 50 year old bathroom and preparing to lay new ones. Bugger of a job getting the old…
20/04/2024
Hi everyone Question about Brevis gas heating undergound - was recently installed by previous owners (<1 year old) but live in a relatively large house - 4 bdr - and only…
