Browse Forums Kitchen Corner Re: An Island bench and power points 4Oct 23, 2007 9:16 pm Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: An Island bench and power points 13Oct 24, 2007 8:16 pm Building again . . with Redink Pre-start 04/12 Keys - 03/13 Finishing off. . . Painting/Floor Tiles/Carpet - 04/13 Walk In Robe/Lighting/Blinds and Moving 05/13 Gates/Front Landscaping / Pool 05/13 Re: An Island bench and power points 14Oct 24, 2007 8:53 pm Dukekamaya commodorenut Check out office fitout mobs - I've seen desks in a few businesses now with pop up panels (hinged) that house power points & data ports. Illegal in a kitchen Is that true? Is it a building regulation/safety thing? Too close to water/liquids? Re: An Island bench and power points 15Oct 25, 2007 8:48 pm Exactly, could you imagine something getting spilt with a power point right there. If you're referring to Eufy homebase, then just put a switch between a datapoint and put the homebase elsewhere near another device in your home unless you want teh… 9 14064 DIY, Home Maintenance & Repair Are you going to have the frame exposed or are you cladding it with something. Usually if you are making an exposed frame you would use solid legs around 100x100 or… 3 7224 Well, it was the default we got with our deign, walking through the build last week felt ok, based on drawings on the floor, it is basically a metre, which is quite a big… 3 824 |
