Browse Forums Kitchen Corner Re: An Island bench and power points 4Oct 23, 2007 9:16 pm Rays right…..they will run the electrical cable under or through your floor. Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: An Island bench and power points 5Oct 23, 2007 9:16 pm Going through similar design issues myself at present.
i like the idea of the pop ups but don;tlike the idea of junk - Kitchens can be messy places - falling into the popup surounds. I'm going for double points at the ends and also one in the centre of the bench which I may hide inside a cupboard and leave a little gap to fit a cable through so it's concealed. The thread on pop ups is here http://forum.homeone.com.au/viewtopic.php?t=2428&start=0 Steve Re: An Island bench and power points 6Oct 23, 2007 9:17 pm steve, you read my mind with that thread. here is link for the powerpoints I found back when we were having that discussion
http://www.formfittings.com.au/eclipse.htm Helen Re: An Island bench and power points 7Oct 23, 2007 9:33 pm I have elected for no exposed powerpoints in my island bench, however the dishwasher is in there and the sink as well. The power is there for later if I change my mind... Re: An Island bench and power points 8Oct 23, 2007 9:54 pm We will be having the same island bench as Matt (100mm sides), so the electrical consultant didn't advise us to have powerpoints at the side.
We just put all power points to the other side of the bench where the upright cooker is. ----------------------------------------------------------------------------------------- Built the Nevada 42 Next project - landscaping! Re: An Island bench and power points 10Oct 23, 2007 10:12 pm The ones I was thinking of work like this one:
http://www.formfittings.com.au/roundbrass.htm However they have additional data points as well. Perhaps a single pop-up is all you need on a benchtop? Re: An Island bench and power points 12Oct 24, 2007 6:24 pm commodorenut Check out office fitout mobs - I've seen desks in a few businesses now with pop up panels (hinged) that house power points & data ports. Illegal in a kitchen Re: An Island bench and power points 13Oct 24, 2007 8:16 pm i wish i had known about these pop ups months ago, oh well i guess i can still get it changed at a later point. They look so much better than having to look at a powerpoint on the bench Building again . . with Redink Pre-start 04/12 Keys - 03/13 Finishing off. . . Painting/Floor Tiles/Carpet - 04/13 Walk In Robe/Lighting/Blinds and Moving 05/13 Gates/Front Landscaping / Pool 05/13 Re: An Island bench and power points 14Oct 24, 2007 8:53 pm Dukekamaya commodorenut Check out office fitout mobs - I've seen desks in a few businesses now with pop up panels (hinged) that house power points & data ports. Illegal in a kitchen Is that true? Is it a building regulation/safety thing? Too close to water/liquids? Re: An Island bench and power points 15Oct 25, 2007 8:48 pm Exactly, could you imagine something getting spilt with a power point right there. If you're referring to Eufy homebase, then just put a switch between a datapoint and put the homebase elsewhere near another device in your home unless you want teh… 9 14023 DIY, Home Maintenance & Repair Are you going to have the frame exposed or are you cladding it with something. Usually if you are making an exposed frame you would use solid legs around 100x100 or… 3 6806 Would also like an opinion from anyone that has used xcem over hebel for floors. Thanks 1 14836 |
