Browse Forums Building A New House Re: custom Build ownit home ownithomes.com.au quote, upgra 33Jun 17, 2019 7:17 pm I agree with their response. The stormwater was obviously designed as a charged system needed to overcome the reverse fall but the grate has broken the seal, thereby creating a lower point of least resistance. If the concreter has altered the original plumbing and created the problem as the case appears to be, the warranty is void (NOT avoided) and not their responsibility as per their communication. I hope that you get it sorted out. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: custom Build ownit home ownithomes.com.au quote, upgra 34Jun 17, 2019 8:12 pm Yes totally agree with what the builder has said, the stormwater was a closed system, the concretor has cut that closed system when installing the grates. It's not an issue with the builder, you will have to take it up the the concretor, good luck with it all and hope it works out. Re: custom Build ownit home ownithomes.com.au quote, upgra 35Feb 23, 2023 10:12 am Hello, I see a couple of you have built with Ownit Homes and should be finished construction by now? I would love to know how it went and if you would recommend them for our build? Please feel free to send me a private message if that is easier. Thanks. Re: custom Build ownit home ownithomes.com.au quote, upgra 36Feb 05, 2024 8:20 pm BrisbaneWestie Hello, I see a couple of you have built with Ownit Homes and should be finished construction by now? I would love to know how it went and if you would recommend them for our build? Please feel free to send me a private message if that is easier. Thanks. They are rubbish , from office to site , poor work quality , rubbish management, no QC, tonnes of reason to get rid of responsibilities, if anyone will to consider them , better avoid or wish you good luck Soak wells and electrical run in happening this week! Summit has told me they will relocate the laundry plumbing after the walls are completed. I'm actually pretty happy… 13 36889 Having just completed our first/only build and we spent so much money on insulation and double glazing upgrades - do not skimp on insulation including upgrade to anticon… 1 2466 I'd get the gutters to match your roof and pipes to match the paint - otherwise they become a feature. Nice pick with the paint colours! 1 35101 |
