Browse Forums Building A New House Re: custom Build ownit home ownithomes.com.au quote, upgra 22Sep 25, 2018 4:37 pm chanam we got 3/4 of acreage HSTP is Home Sewage Treatment Plant is a modern device that treats all the waste water that is generated in a domestic dwelling. it cost around 10 to 12k. Most like you have sewerage on your land if it is Residential Category A. it is council requirement. Ownit advice me they are going to send building specification today afternoon with variation we end up spending $33k in colour selection including render kitchen bench top , semi-frame to frame less couple of other things. What is electrical allowed in your home . how many points ? Re: custom Build ownit home ownithomes.com.au quote, upgra 23Sep 25, 2018 4:39 pm chanam By the way, are you doing turnkey or including floor coverings and all light fitting (downlights) with oih? Can't afford it turnkey mostly things doing after hand over bit by bit Re: custom Build ownit home ownithomes.com.au quote, upgra 24Sep 25, 2018 5:02 pm Finally I have some updates for ownit homes colour selection . Colour selection is very rocky road we have ups and down and I am glad mostly matter get sorted in good way on the principal of give and take. We end up spending around $33K . They allow us to change few things before I sign the building specification document including colour schema. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: custom Build ownit home ownithomes.com.au quote, upgra 25Sep 25, 2018 5:16 pm nafeesra @chanam we got 3/4 of acreage HSTP is Home Sewage Treatment Plant is a modern device that treats all the waste water that is generated in a domestic dwelling. it cost around 10 to 12k. Most like you have sewerage on your land if it is Residential Category A. it is council requirement. Ownit advice me they are going to send building specification today afternoon with variation we end up spending $33k in colour selection including render kitchen bench top , semi-frame to frame less couple of other things. What is electrical allowed in your home . how many points ? 38 light points allowed. We've included led light instead of batten holder for $3500. Our additional spend sits at $15k currently . covers timber stairs,increasing height of overhead cupboard, upgrading to oven plus other small items...which all adds up. Re: custom Build ownit home ownithomes.com.au quote, upgra 26Sep 25, 2018 5:17 pm nafeesra chanam By the way, are you doing turnkey or including floor coverings and all light fitting (downlights) with oih? Can't afford it turnkey mostly things doing after hand over bit by bit Same, not doing turnkey. Doing floor coverings after handover. Re: custom Build ownit home ownithomes.com.au quote, upgra 27Sep 25, 2018 5:23 pm nafeesra Finally I have some updates for ownit homes colour selection . Colour selection is very rocky road we have ups and down and I am glad mostly matter get sorted in good way on the principal of give and take. We end up spending around $33K . They allow us to change few things before I sign the building specification document including colour schema. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Fantastic news they allow you changes to things before signing specification. It is definitely a rocky road. We're still holding onto the initial colour selection sheet to really think things through.😊 Re: custom Build ownit home ownithomes.com.au quote, upgra 28Oct 02, 2018 7:44 pm I have signed off buildings specification on Friday 29 September. Got very quick response for slab dates 03.10.18 SITE CUT 05.10.18 SURVEYOR PEG 8 & 9.10.18 UNDER GROUND DRAINS & ELECTRICAL Note: The drainage work may exceed 2 days in which case the slab dates will be adjusted to suit. We will advise you of any changes as they come to hand. 10.10.18 SLAB PREP 11.10.18 SLAB POUR Re: custom Build ownit home ownithomes.com.au quote, upgra 29Oct 19, 2018 11:58 am Some updates . Slab was planned to be pored on 11 October. They prepare for the slab on 11 but due to bad weather they aborted . Bad weather last one week . On Wednesday 17 October they prepare for slab again and empty the water from pillar and pour the slab on 18 October. Frame was planned on 18 October . Today I have visited the construction site chippy already working on Frame so I miss only one day. I want to upload some pictures . Someone tell me how you upload picture from mobile on android phone because on mobile view forum.homeone.com.au did not give you option to post in Full editor Re: custom Build ownit home ownithomes.com.au quote, upgra 30Oct 29, 2018 12:36 pm Over the weekend done tile selection waiting for Tiles update price cost.
Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: custom Build ownit home ownithomes.com.au quote, upgra 31Oct 29, 2018 12:39 pm Some pictures during different stages of build Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: custom Build ownit home ownithomes.com.au quote, upgra 32Jun 17, 2019 5:02 pm Yesterday we got first heavy rain . The storm water was blocked .
ownit home told me downpipes are glued and sealed off at the connection point to the underground drainage system that leads to the stormwater pit. They also mentioned me that the concreter has cut into the stormwater line by installing the grate creating a break in the line at the down pipe connection. which in turn , all the water from your down pipe is directly flowing out the boxed drain where they have cut into the line causing it to bubble and overflow. Driveway was never part of our contract and is an issue for you to take up with my concreter as I am now voiding warranties. Ownit has mentioned me that on day of handover they have strongly advise me to run a separate line from all my drainage connection points at the front of my property. The lie of my land from the street to your home falls directly to my home where it needs to be controlled and picked up with stormwater pits/drains to the stormwater pit directly, not via the house stormwater lines as their system is not designed for this amount of water. I have asked ownit home director which handover document it has mentioned to run a separate line from all your drainage connection points at the front of your property which causing me avoiding my home warranties. He mentioned it is not in writing Just have a conversation. where As I can remember this conversation never took place. I have forward their email to people who done my driveway Re: custom Build ownit home ownithomes.com.au quote, upgra 33Jun 17, 2019 7:17 pm I agree with their response. The stormwater was obviously designed as a charged system needed to overcome the reverse fall but the grate has broken the seal, thereby creating a lower point of least resistance. If the concreter has altered the original plumbing and created the problem as the case appears to be, the warranty is void (NOT avoided) and not their responsibility as per their communication. I hope that you get it sorted out. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: custom Build ownit home ownithomes.com.au quote, upgra 34Jun 17, 2019 8:12 pm Yes totally agree with what the builder has said, the stormwater was a closed system, the concretor has cut that closed system when installing the grates. It's not an issue with the builder, you will have to take it up the the concretor, good luck with it all and hope it works out. Re: custom Build ownit home ownithomes.com.au quote, upgra 35Feb 23, 2023 10:12 am Hello, I see a couple of you have built with Ownit Homes and should be finished construction by now? I would love to know how it went and if you would recommend them for our build? Please feel free to send me a private message if that is easier. Thanks. Re: custom Build ownit home ownithomes.com.au quote, upgra 36Feb 05, 2024 8:20 pm BrisbaneWestie Hello, I see a couple of you have built with Ownit Homes and should be finished construction by now? I would love to know how it went and if you would recommend them for our build? Please feel free to send me a private message if that is easier. Thanks. They are rubbish , from office to site , poor work quality , rubbish management, no QC, tonnes of reason to get rid of responsibilities, if anyone will to consider them , better avoid or wish you good luck Soak wells and electrical run in happening this week! Summit has told me they will relocate the laundry plumbing after the walls are completed. I'm actually pretty happy… 13 36639 Having just completed our first/only build and we spent so much money on insulation and double glazing upgrades - do not skimp on insulation including upgrade to anticon… 1 2191 I'd get the gutters to match your roof and pipes to match the paint - otherwise they become a feature. Nice pick with the paint colours! 1 35039 |
