Browse Forums General Discussion 1 Jul 26, 2023 8:25 pm Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hi all, before I waste more money on a building inspection and not get the home, I am just wondering if anyone on this forum knows if it's ok for this rendered brick veneer home to not have any weep holes above windows and the damp proof course. I thought it was building code for brick homes in Australia to have them? Re: Weep holes required? 2Jul 26, 2023 8:43 pm Benny123 Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hi all, before I waste more money on a building inspection and not get the home, I am just wondering if anyone on this forum knows if it's ok for this rendered brick veneer home to not have any weep holes above windows and the damp proof course. I thought it was building code for brick homes in Australia to have them? You should absolutely pay for a pre-purchase inspection because a competent inspector will see more than you do. Weep holes are not required if the wall is painted with waterproof coating, Its in NCC DPC can be flashing, but some of the older homes have DPC in the mortar, I know brickies were using liquid DPC in mortar in seventies and eighties. Yes so it could be all good but you wont know if you dont pay for good advice, there is a lot more you wont know and you will be underwriting your own risk. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Weep holes required? 3Jul 26, 2023 8:59 pm building-expert Benny123 Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hi all, before I waste more money on a building inspection and not get the home, I am just wondering if anyone on this forum knows if it's ok for this rendered brick veneer home to not have any weep holes above windows and the damp proof course. I thought it was building code for brick homes in Australia to have them? You should absolutely pay for a pre-purchase inspection because a competent inspector will see more than you do. Weep holes are not required if the wall is painted with waterproof coating, Its in NCC DPC can be flashing, but some of the older homes have DPC in the mortar, I know brickies were using liquid DPC in mortar in seventies and eighties. Yes so it could be all good but you wont know if you dont pay for good advice, there is a lot more you wont know and you will be underwriting your own risk. Thanks for your advice. I have been getting quite a few building inspections lately and will continue to do so for sure. Just wanted to know if this home needed them as I'd walk away if it did. But now it's probably worth pursuing further and getting an inspection. Re: Weep holes required? 4Jul 27, 2023 4:23 am Benny123 Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hi all, before I waste more money on a building inspection and not get the home, I am just wondering if anyone on this forum knows if it's ok for this rendered brick veneer home to not have any weep holes above windows and the damp proof course. I thought it was building code for brick homes in Australia to have them? Hey Benny, Seeing no weep holes can also be a sign that it's Hebel or foam and not brick. You can tell by giving it a good whack with your hand Cheers Simeon Architectural Homes & Duplexes - specialising in custom designing homes to your budget Get a Free Onsite Consultation Today or send a PM for information, questions or advice. Re: Weep holes required? 5Jul 27, 2023 1:09 pm Ashington Homes Benny123 Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hi all, before I waste more money on a building inspection and not get the home, I am just wondering if anyone on this forum knows if it's ok for this rendered brick veneer home to not have any weep holes above windows and the damp proof course. I thought it was building code for brick homes in Australia to have them? Hey Benny, Seeing no weep holes can also be a sign that it's Hebel or foam and not brick. You can tell by giving it a good whack with your hand Cheers Simeon i think the style of the construction might predate those materials/methods, no? Re: Weep holes required? 6Jul 27, 2023 2:11 pm ponzutwo Ashington Homes Benny123 Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hi all, before I waste more money on a building inspection and not get the home, I am just wondering if anyone on this forum knows if it's ok for this rendered brick veneer home to not have any weep holes above windows and the damp proof course. I thought it was building code for brick homes in Australia to have them? Hey Benny, Seeing no weep holes can also be a sign that it's Hebel or foam and not brick. You can tell by giving it a good whack with your hand Cheers Simeon i think the style of the construction might predate those materials/methods, no? I know foam has been around since the 90's and CSR started manufacturing Hebel in 1989, so it's definitely possible Architectural Homes & Duplexes - specialising in custom designing homes to your budget Get a Free Onsite Consultation Today or send a PM for information, questions or advice. it depends on the natural ground level, if they excavated their boundary wall needed to be built as a retaining wall. If you filled, which sounds like the case then you… 1 7579 You are correct. Just read through all the ncc rules and 75mm is the minimum requirement for me. 4 11953 Building Standards; Getting It Right! Hi, sorry if this is the wrong place - I’m new to the property/building journey (trying to buy my first home) so not sure where/who to go with these sorts of… 0 20157 |
