Browse Forums Renovation + Home Improvement Re: How good/safe is Flat roof? 2Jan 01, 2013 7:47 pm A flat or semi-flat roof with the right profile of roof sheeting is fine. What's not 'safe' is when walls are extended up to hide the roof profile and then have a concealed box gutter behind the wall. While builders say that they don’t leak, homes with box gutters that I’ve looked at buying before deciding to build, all had evidence of water damage due box gutters above. The facade you linked to will be fine if roof profile behind the walls drains away from the parapets. Good luck! ----------------------------------------------- http://pab34newdigs.blogspot.com.au/ ----------------------------------------------- Re: How good/safe is Flat roof? 4Jan 01, 2013 8:16 pm I'm not a big fan of a flat, or flat looking, roof. In my opinion they are either very expensive and/or are at high risk of water damage to the rooms below(for more see http://www.anewhouse.com.au/?p=3579) The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: How good/safe is Flat roof? 5Jan 02, 2013 7:06 pm Phillip Murray Flat roofs have some distinct advantages over their sloped counterparts. One of the most obvious advantages is that flat roofs are easier to climb up on and inspect. Although any excursion to the roof should be dealt with using care and caution, flat roofs offer significantly more stability and horizontal surface than sloped roofs do. Another benefit of flat roofs is that they are cheaper to re-coat and install than sloped roofs. However, this is a tricky point, because flat roofs need to be re-coated and sealed every few years to help them maintain their integrity and prevent leaks. If the roof is not properly cared for, there can be a need for replacement much sooner which would make a sloped roof actually more cost effective. As written in roofer911.com. Re: How good/safe is Flat roof? 7Jan 04, 2013 7:46 am Every time I've seen somewhere with a flat roof I've heard of never ending leaks, I'd never do it. your probably right, it is maintenance, but who wants to do any work on the roof Slooowwwwly getting a Manhatten 35 in Middleton Grange Re: How good/safe is Flat roof? 8Jan 04, 2013 10:17 am Not at all. If you have a competent roofer and/or builder supervising then you won't have any problems. A lot of the issues arise from the design side where there is not enough room ( usually height ) for a decent box gutter or flashings. Get this right from the get go and that is half your problems solved. Stewie Re: How good/safe is Flat roof? 9Jan 04, 2013 10:24 am to be fair, all my issues with horizontal roof's leaking are generally due to bad workmanship of people installing things after the fact (so tradies stuffing up the sealing or causing leaks by drilling things into the roof and not sealing adequately around them, or the sealant not lasting) but how often do you hear of this on a normal roof? they are pretty bullet proof. Slooowwwwly getting a Manhatten 35 in Middleton Grange Re: How good/safe is Flat roof? 10Jan 04, 2013 10:44 am A mate - across the road in my old place - never stops complaining about it. Mainly the cleaning side. He mentioned leaks but its mainly the leaves etc. It looks good though. Re: How good/safe is Flat roof? 11Jan 04, 2013 10:47 am Depending on how it's done it's very hard to add in wiring/systems in the roof as well, that's where you get tradies making holes in the roof to throw stuff on top and causing leaks Slooowwwwly getting a Manhatten 35 in Middleton Grange I would suggest you simply go and talk to council about your proposal, most councils are getting onboard with ancillary dwellings. There is no benefit in keeping it… 1 4478 I think I know the answer but just checking to see if anyone has had experience with it. I want to build a small 20 square metre retreat in my backyard, it will have a… 0 15023 Any advice on how to ensure the kit home granny flat that im thinking of buying will get council approval. The kit home companys wont release plans without a deposit and… 0 7884 |
