Browse Forums Landscape & Garden Design Re: Espaliering fig against wall 5Nov 24, 2012 6:31 am Stewie D You could try a S/steel supply place to see if they have anything that is stock standard but I doubt it myself. You could get something made quite easily though and any fitter & turner would be able to knock something up easily. We had to get some special brackets made for an air con unit years ago that were something similar. Basically a 150mm long 10mm S/Steel rod with an internal thread at each end. One end was screwed onto a masonry bolt that was inserted into the brickwork and we screwed a bracket to the other end. You could use an eyelet or hook for this end instead. Stewie Seeing that you are also in Sydney, who did you use? I found most shops were: "This is what we have..." Re: Espaliering fig against wall 7Nov 25, 2012 6:29 am Managed to find Ronstan, a company that makes a system. For those interested... http://www.ronstanrigging.com/arch_au/AGS2R.asp DIY, Home Maintenance & Repair I'm in WA and our sandy soils make drainage a bit easier but this is what I'd be doing. Dig down to your footings and let the wall dry out. Clean it all well by brushing… 1 6258 6 5545 Good on you for having a go I am the opposite of DIY (so will pay a builder) - our vibe is industrial/simple so current thinking is 150mm concrete and then internally is… 3 3258 |
