Browse Forums Kitchen Corner Re: What depth is your island bench? 3Oct 05, 2012 7:35 am Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: What depth is your island bench? 7Oct 05, 2012 8:11 am xxkatxx 900 seems to be the standard for most builders...600 for cupboards and 300 for overhang of breakfast bar. would be nice to go wider but 900 seems fine to me from what I've seen and sat at in the display homes. Agreed 900mm is standard for spec build homes. It costs the builder alot less! If you have control of your build and can design you kitchen I would go wider. I think 900mm unless its a small kitchen looks underdone! Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: What depth is your island bench? 8Oct 05, 2012 8:22 am Ours is 1500mm wide, it's the width of the stone, plus another 300mm for a laminate breakfast bar type thing. Re: What depth is your island bench? 10Oct 05, 2012 11:27 am If and when the house actually gets build mine will be 3m long by 1.2m deep. I agree with CEK, essentially get the size that suits the space. Re: What depth is your island bench? 14Oct 05, 2012 2:29 pm The biggest that can fit in your space preferrably using a single sheet of stone is better, ours is big 1400 deep by 2806 long and i would have liked it to be deeper and longer.. Building Henley Monaco Nouveau Q1 - Mernda Villages https://forum.homeone.com.au/viewtopic.php?f=31&t=57810 http://razbuild.blogspot.com.au/ Re: What depth is your island bench? 15Oct 21, 2012 5:42 pm Although not technically an island, my kitchen bench is 125 cm deep - with 60cm cupboards one side, 30cm cupboards & 30cm overhang for breakfast bar. I love the size as it gives me lots of room to work & lay out cookie sheets etc, but when clearing & cleaning it I can't reach from one side to the other, so I have to walk around it to get the dirty breakfast dishes and wipe it clean, which is a little annoying. But then, I am a shorty! Re: What depth is your island bench? 16Oct 21, 2012 9:57 pm In our plans ours is 1m wide by 4.5m long. I am hoping it works well, we have the 400mm breakfast bar and on one end there is 700mm that is cantilevered so we can sit around it like at a table. Re: What depth is your island bench? 19Oct 22, 2012 6:11 pm idream3 Our just completed kitchen has a 3m x 1.2 and we love the size And the good thing about this size is it fits within a single slab of Caesarstone, so no join! Demolition August 2009, Construction Started September 2009, Completed December 2010 Re: What depth is your island bench? 20Oct 24, 2012 8:54 pm Holy crap, you guys are crazy. We are building our new house and I'm excited about our 60cm deep island. I thought that was standard size, although I've seen deeper narrower ones too of course. But not a single one has mentioned a 60cm deep one yet :p It's 250cm wide. The distance between my DEBs varies from 4.1m at the narrowest to 8.1m at the widest. 5 27916 Hi, only for walking. It is a narrow 1.5m paved area next to house. 2 6040 DIY, Home Maintenance & Repair Are you going to have the frame exposed or are you cladding it with something. Usually if you are making an exposed frame you would use solid legs around 100x100 or… 3 7295 |
