Browse Forums Building A New House Re: Anyone else building in North Kellyville? 42Jul 12, 2012 8:10 pm rix that's awesome... have you submitted your plans to CDC yet? it's going to be busy days ahead. nope! need to make more changes first... Have you? I didn't know anyone was that far ahead of me! Yes busy times ahead. Might take some time off work to make sure the builder is getting on to it. Re: Anyone else building in North Kellyville? 43Jul 12, 2012 8:33 pm daveinthehills rix that's awesome... have you submitted your plans to CDC yet? it's going to be busy days ahead. nope! need to make more changes first... Have you? I didn't know anyone was that far ahead of me! Yes busy times ahead. Might take some time off work to make sure the builder is getting on to it. next week probably... the person in Alk1r4 organising plans with council/CDC unfortunately doesn't work on Fridays so it'll have to wait until Monday. we only had minor changes in the plan. Re: Anyone else building in North Kellyville? 44Jul 13, 2012 8:48 pm Hi everyone, First time poster, we are building in North Kellyville Murrayfield Ave. We are also looking at building an Eden Brea Cremorne 37. This is our second building experience but the last one was 15 years ago. There are more requirements now , like raingardens looks like the builders want to over charge on this. We have been quoted $6,000, this is a lot for a 4 Sqm, 60cm deep detention pit. Also on the ridge side of North Kellyville u need to put in a 4000 litre water tank. If u are on the smalls creek side it is 3000 litres. I think Eden Brea do charge higher site costs but the overall costs because of including inclusions, free air con, big space and living essentials mean the price is reasonable overall. Great news during the week we have registration.... Re: Anyone else building in North Kellyville? 45Jul 13, 2012 9:39 pm Gday Cremorne37! Yeah the raingarden and tank are annoying I gotta say. Look forward to seeing some plans when you have then We are gonna get our second lot soon enough and if we work hard can start building next month when its all settled (26th July is the settlement date we have) Re: Anyone else building in North Kellyville? 46Jul 15, 2012 6:38 am Cremorne37 There are more requirements now , like raingardens looks like the builders want to over charge on this. We have been quoted $6,000, this is a lot for a 4 Sqm, 60cm deep detention pit.. Hey C37, Welcome to the thread. $6000 seems a bit steep. Really its just a hole backfilled with sand/gravel etc. Attached is the raingarden details that our Developer has submitted to council.Similar size to what you are describing. Some quick calculations and i come up with this costing. Excavation & Spoil removal Bobcat 1/2 day $400 Spoil Removal $400 Plumber 1/2 day labour $200 Material $200 Sand / Gravel 2tonne @ say $100/tonne $200 Geofab liniing $100 Labour 1 man 1 day $400 Ancillary items Say $100 I am assuming planting is not included in your quote Total Excavation / Labour / Material $2000 Even if you add a builders margin of say 50% you should be looking at around the $3000 mark. I am assuming this cant be done after handover as it needs to be passed with the occupation certificate otherwise you could save a few bucks and do it with your driveway / landscaping. Anyone one else had firm prices on the raingarden from your builder? Cheers Re: Anyone else building in North Kellyville? 47Jul 15, 2012 9:04 am Hi Pepe, Thanks for the additional information. I agree around the 3k mark is reasonable for the work. I did receive a quotes from another two builders. One was just under 3k and the other was over 8k. Would prefer to use my own landscaper/plumber but the builder said this will interfere with the certification process? Also does anyone know what the bushfire requirement in North Kellyville is? I checked the map and we are in the white zone. Still need a copy of the 149 certificate, which will now be available with the recent registration. Re: Anyone else building in North Kellyville? 48Jul 15, 2012 10:13 am There is a new bushfire map as of 12th May 2012 apparently - and our little area is not in a bushfire zone anymore. Highbury was affected, but it now not. As for the raingarden, our builder doesn't do them at all - their plumber or drainer will supply a capped off point, and we can DIY it, (very tempted) or get a landscaper to do it. Re: Anyone else building in North Kellyville? 49Jul 15, 2012 4:10 pm Hey Dave & C37. Dave Yeah it makes more sense to have the raingarden constructed during landscaping. Definitely something to consider doing after handover as logistically it makes more sense and cost wise there would be a saving. C37 If you are in a Bushfire prone area this link is really helpful in identifying what is required to comply. http://hia.com.au/upload/hia/documents/ ... redoc2.pdf . I am in a BAL12.5 level prone area. I have done a little research and it looks like about $5000 worth of extras to comply. Cheers Re: Anyone else building in North Kellyville? 51Jul 17, 2012 8:41 pm daveinthehills There is a new bushfire map as of 12th May 2012 apparently - and our little area is not in a bushfire zone anymore. Highbury was affected, but it now not. As for the raingarden, our builder doesn't do them at all - their plumber or drainer will supply a capped off point, and we can DIY it, (very tempted) or get a landscaper to do it. Here is the link of the bushfire prone zone http://www.thehills.nsw.gov.au/Ignition ... et%206.pdf It appears that we're not in the bushfire zone however it says on the registered land contract I received today - 149 certificate (section 7ii and 11) that we are bushfire prone. Also, can anyone confirm whether we can indeed go through CDC instead of council? As it also says on the 149 cert (section 3) under General Housing code that CDC may not be carried out however under Housing Alterations Code may.. Cheers, Leo Re: Anyone else building in North Kellyville? 52Jul 17, 2012 8:43 pm I thought it was pretty clear all along we are CDC (attn johnglendenning!) Our builder wasn't aware of it, and went away and did their research, and now are all on board with the process. Russell as pretty clear about that upfront that it was all CDC, part of the reason for the sale to us really. Oh and I can give you the number of a bush fire consultant if you like. He has confirmed my father in law's lot on the corner of bellerive and highbury is not bushfire affected at all. Quite possible they re-drew the map after the land contract was drawn up. Re: Anyone else building in North Kellyville? 53Jul 17, 2012 9:30 pm Sure - call 4577 0100 and ask for Craig at Control Line Consulting. He knows the area and can assist if required. (that number is also the number of our lawyer, A R Walmsley and Co, who can help with legal things) ARwalmsley are already doing 3 contracts for the land in North Kellyville. Re: Anyone else building in North Kellyville? 54Jul 17, 2012 9:48 pm 2 properties along Highbury Road have submitted their plans for approval. One of them is H&L Package with Alk1r4 and was submitted just today through CDC. You may view them in 'Application Tracking' under 'Planning and Development' section of The Hills Shire Council website. Our plans unfortunately are being re-drawn simply due to change in windows/door height! Re: Anyone else building in North Kellyville? 55Jul 17, 2012 9:58 pm yeah we would have been ready to go, but our dropped garage has delayed things and they need to be redrawn. We also managed to convince the builder that our driveway could be a little steeper than they though (22% instead of 16%) so we can get back 2 courses of bricks cutting, and have a flatter block. Re: Anyone else building in North Kellyville? 56Jul 17, 2012 10:09 pm daveinthehills yeah we would have been ready to go, but our dropped garage has delayed things and they need to be redrawn. We also managed to convince the builder that our driveway could be a little steeper than they though (22% instead of 16%) so we can get back 2 courses of bricks cutting, and have a flatter block. that's really an excellent alternative... ours has about 1.5m of 22% but the remaining 4m is at 12.5%... so looks like there's room for us also considering our blocks have similar sloping profile. with your new 22% grade, what is now the floor level difference between your garage and main floor? Re: Anyone else building in North Kellyville? 57Jul 17, 2012 10:12 pm rix with your new 22% grade, what is now the floor level difference between your garage and main floor? Not sure - will have to get then plans back from the drafter next week to be sure. I am hoping we go from 10 courses to 8 courses of bricks. Re: Anyone else building in North Kellyville? 58Jul 18, 2012 7:46 pm HI checked yesterday with council, our property on Murrayfield Ave is not bush fire affected. I am waiting for the full 149 to confirm. Dave Iam keen on CDC but with a project builder not sure if it will speed the process up? They have allocated a late November start. Re: Anyone else building in North Kellyville? 59Jul 18, 2012 9:31 pm I have also confirmed through Dave's contact that our area is not bush fire prone... I noticed that the 149 cert was dated 8th Aug 2011 which is why bushfire & CDC details are outdated. I have requested an updated version of the 149 cert. Things are looking up Re: Anyone else building in North Kellyville? 60Jul 18, 2012 9:52 pm Cremorne37 HI checked yesterday with council, our property on Murrayfield Ave is not bush fire affected. I am waiting for the full 149 to confirm. Dave Iam keen on CDC but with a project builder not sure if it will speed the process up? They have allocated a late November start. Hi, I don't know why you wouldn't go with the CDC process given the chance. Speedy approval seems to make sense to me. Late november start seems slow, but again I have no idea, I'm new here. Petercurtis You able to contact the certifier and get a copy of your structural plans, if they are not in your contract. If your home was approved via CDC then they… 1 20653 3 23273 A survey must’ve completed by a certified surveyor. This form part of every DA requirement 3 226369 |
