Browse Forums Flooring & Floor Covering Re: brand new bamboo, installer has left scratches. 2Dec 30, 2011 6:51 pm Bamboo Flooring Perth - Simply Bamboo http://www.simplybamboo.com.au Re: brand new bamboo, installer has left scratches. 3Dec 30, 2011 6:58 pm Hi Bamboo King Are you saying it is easier to replace direct stick rather than the click boards. I was going to go for a flaoting floor just because i thought it would be easier to replace or repair them. Am i naive? Sorry Mary to hijack your thread. It is really scary to think you do all this planning and then someone else is so careless with your floor. KDRB Carlingford, NSW Building Garden Retreat with MDJH Re: brand new bamboo, installer has left scratches. 4Jan 09, 2012 8:04 pm KTKTKT Hi Bamboo King Are you saying it is easier to replace direct stick rather than the click boards. I was going to go for a flaoting floor just because i thought it would be easier to replace or repair them. Am i naive? Sorry Mary to hijack your thread. It is really scary to think you do all this planning and then someone else is so careless with your floor. Hello If the damaged boards are near the wall then would be easier to un -click and replace with new boards, but we all know that most of the time the damaged boards are in the middle of the room, so with direct stick, the board is cut out using a circular saw. With the new board the underneath of the groove on the side and the end are cut, then the back of the board is glued,the tongue can go in first and then the board can be push level to the other floor. Damaged in middle of room. If un-click you would have to unclick the floor taking of the beading until you get to the damaged board and then you would have to re lay, so would be quicker to remove the board if was direct stick. Hope this helps Bamboo Flooring Perth - Simply Bamboo http://www.simplybamboo.com.au Re: brand new bamboo, installer has left scratches. 5Jan 09, 2012 8:19 pm It really does help. Thank you for your very clear explanation. I 'm in Sydney. If I was over west I'd be giving you a call for a quote. KDRB Carlingford, NSW Building Garden Retreat with MDJH Re: brand new bamboo, installer has left scratches. 6Jan 09, 2012 9:19 pm sorry for the late reply bamboo king, but alas is not direct stick.That was one of the first things I asked my husband was can we replace the scratched boards, but meant having to pull up most of the floors as yes most of the damaged ones are in the middle of the room. and would have loved your help but Im a long way off from perth, down in south oz. Pay again? No retribution? Your glass has a specific performance get this app and see how much your windows are leaking, then challenge the supplier. 3 5053 you need a fridgie to answer but I would think you vac the whole system then add gas if you have a leak, unless it is new install with the gas already loaded, in that case… 1 3957 Old Home Restoration / Renovation Hi, just discovered all these junks left behind under the floor. Could any of these be asbestos? Best to leave as it is or clean up? Thank you for your thoughts 0 9947 |
