Browse Forums General Discussion Re: Home Design in Perth for $250,000 2Nov 01, 2011 10:39 am House - Lockup completed 23rd December 2011 - Painters are in!!! https://forum.homeone.com.au/viewtopic.php?f=31&t=37261&start=0&hilit=Blaxland Re: Home Design in Perth for $250,000 5Nov 01, 2011 8:56 pm The main point of my question: are you better off with less inclusions from APG/WBH/Summit/RedInk than with "everything under the sun" from "Homebuyers" for the same amount of money... My answer is NO! Absolutely not. You can build with a more expensive builder and you will get the same quality as the homebuyers house. All the tradesmen they use are the same. The kitchens all come out of the same factory. What you are paying the extra for is the additional structural features ie 31c ceilings, recesses, windows, the facade and mainly the specification is what determines price. Price has no bearing on quality of workmanship. It depends on your tradesmen and if you get a good supervisor. The same tradesmen will build your house. If you build a Homebuyers house the same guy that does your ceiling is the same guy that does the Webb Brown house round the corner. Quality does not come into it. The reason why a Webb Brown house is more expensive is because its all inclusive and you get a choice of whatever you want. It has everything in it and everything is pretty much upgraded. Price does not guarantee a quality build. Where there is a difference is in the following: With Celebrations they will not let you upgrade the bathroom floor tiles larger than 200x200mm. Dales will at a cost however WBN its all included in the price. Homebuyers from memory do not do stone benchtops (correct me if I am wrong here) Celebrations allow you to have a stone benchtop. However not one that is thick and they will not allow you to have an undermount sink or waterfall ends. With Dales you can get the stone at any thickness for a cost, an undermount sink and waterfall ends at a cost however with WBN you get the undermount standard as you have paid for an all inclusive package. Celebrations will not do an aggregate driveway. Dales will for a cost. It may be included with the WBN home. Celebrations do not do soakwells. Dales do. I hope this makes sense. However dont believe the bull they spin you when you go through the displays. A brickie does not care what you spent on the house. If he is going to do a crooked wall he will do it on a 300K house as well as a 150K house if he can get away with it. (I am not saying brickies are bad this is an example only) If you can get a house will all the works for 250K why would you pay more for less stuff when its the same people building your house?? The workmanship will be the same. Cheers Re: Home Design in Perth for $250,000 6Nov 02, 2011 1:50 pm Have recently completed a 4 x 2 in Perth for similar money....best to design yourself or get an architect with separate builder....mine is pretty good. My spec includes double glazed windows and doors, insulated walls ceiling and roof....just remember the 6 star rating that will shortly be required with regard to insulation....happy to help....Bob Home Design in Perth for $250,000 7Nov 02, 2011 2:05 pm Agree with what Luke said, which is a much better version if something I said in your last thread. my new build thread- Ben Trager https://forum.homeone.com.au/viewtopic.php?f=31&t=89826 my switch build thread (2011) https://forum.homeone.com.au/viewtopic.php?f=31&t=36569 Re: Home Design in Perth for $250,000 8Nov 24, 2011 9:55 pm Im new here but i do agree with Luke81 most trades are used throughout the housing industry in Perth are working for all the builders, it comes down to the supervisor that is working on your house as most of them have there certain trades that do most of there houses, in saying that it doesnt mean you will get a proper job. Personally i would go to a smaller builder, who owns the company and supervises the build. Dan As is per usual for many of the past failed RWH regulations, it is probably traceable to a bureaucrat who's ego overrode the need to seek the appropriate expert… 1 1630 ideal house depends on the site and location as much as internal floor plan....what is the distance from the house to all four boundaries, where is north, describe your… 3 16045 Although I am a big opponent of using waffle pod slabs over H2/P soils under any circumstances, in your case I would certainly opt in to keep piers under central… 1 2664 |
