Browse Forums Building A New House Building a Sunnydale with Clarendon - week 7 summary 61Oct 12, 2011 9:26 pm My Build:https://forum.homeone.com.au/viewtopic.php?f=31&t=50541&p=772361#p772361 site start: 24/8/11 slab: 5/9/11 frame: 21/11/11 lock-up: 6/6/12 Re: Building a Sunnydale with Clarendon 63Oct 12, 2011 9:49 pm My Build:https://forum.homeone.com.au/viewtopic.php?f=31&t=50541&p=772361#p772361 site start: 24/8/11 slab: 5/9/11 frame: 21/11/11 lock-up: 6/6/12 Re: Building a Sunnydale with Clarendon 67Oct 13, 2011 9:05 pm My Build:https://forum.homeone.com.au/viewtopic.php?f=31&t=50541&p=772361#p772361 site start: 24/8/11 slab: 5/9/11 frame: 21/11/11 lock-up: 6/6/12 Re: Building a Sunnydale with Clarendon 70Oct 14, 2011 7:46 pm I don't believe that I will be getting sarking. There is insulation in the ceiling...so that should do the trick! I don't know, however, if there is insulation above the garage, the section that is underneath the first floor area....need to sort something out if there isn't...unless anyone has any strong suggestions here. Anyway, had our first delivery of bricks and the front door frame today! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ My Build:https://forum.homeone.com.au/viewtopic.php?f=31&t=50541&p=772361#p772361 site start: 24/8/11 slab: 5/9/11 frame: 21/11/11 lock-up: 6/6/12 Re: Building a Sunnydale with Clarendon 71Oct 15, 2011 9:03 am rjg I could be wrong - but I don't think there was any wrapping done for my house.... I know that the wrapping isn't there as I can see large sections from the inside of the house where I can see the wood, and then the brick. I presume it would be between these? BTW; I didn't get sarking either though - I nkow they 'sarked' sections where the downspouts joined tiles though - I guess this was a freebie or already part of the house. When you say 'large sections', do you mean just particular areas or throughout your house? The foil wrapping goes between your bricks and frame. Check your contract drawings. it should be mentioned on one of the pages after the Elevations, a small box named Insulation. As katman said, sarking is not really necessary, your roof insulation should take care of it. Building a Sunnydale with Clarendon - week 8 summary 72Oct 19, 2011 9:42 pm Week 8 and not a fast week on the build, but something seemed to happen every day.... Met with the site supervisor....that went well. Had some bricks delivered...well they are still sitting there (tanning since it has been nice weather this week). Most of the upstairs windows have been installed Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ as well as a steel beam for the garage Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The front door frame has been installed Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ the glass is known as 'rice paper'! The gutters and fascias have been installed around the family room. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ and found a slight bow in the frame around a door way (must ask about that one...only noticed it today). Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Having said all that...the frame itself isn't quite complete. 3 weeks since they sent the invoice for the frame...makes me feel glad that we insisted on the standard HIA payment schedule! 38 weeks to go! My Build:https://forum.homeone.com.au/viewtopic.php?f=31&t=50541&p=772361#p772361 site start: 24/8/11 slab: 5/9/11 frame: 21/11/11 lock-up: 6/6/12 Re: Building a Sunnydale with Clarendon 73Oct 22, 2011 4:30 pm The past two days have been busy in terms of some of the internal works. Plaster has been delivered, Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The baths have been delivered, Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The air conditioning/heating ducts have got a rough-in, Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ However, we have a slight issue….the void where the return air is supposed to run is a bit small and would need to go through a roof truss. Not a good idea to cut through a roof truss, so I am expecting a phone call from my SS as to alternatives. There is a possibility for two return air vents upstairs, which then gives me an empty void downstairs. Need to think about I could do with the void if that is the case! While the installers were on site, I managed to negotiate another duct. I realised I didn’t have one in the laundry, so a quick phone call later, its all settled! The electrician (well his apprentice) has also been in to do a rough in of plates for the switches and plugs Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Lucky I have been through, because 2 plugs were totally in the wrong spot for my intention! The apprentice managed to move them without issue. I still want to speak with the electrician about some extra lights, recessed plugs for behind the TV and even some speaker and DVD cables! My Build:https://forum.homeone.com.au/viewtopic.php?f=31&t=50541&p=772361#p772361 site start: 24/8/11 slab: 5/9/11 frame: 21/11/11 lock-up: 6/6/12 Building a Sunnydale with Clarendon - week 10 summary 74Nov 01, 2011 7:22 pm Ten weeks into the build…where has time gone! (Sorry for not doing a week 9 update!) I spoke with the heating/cooling guys who put in an extra air pipe for the laundry (at a cost, but directly to the heating/cooling company rather than the builders!). All is good, but they tried to put the extra pipe into a hole through the floorboards with another pipe which is not quite big enough. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I rang the heating/cooling company to see if they could widen the hole…they were going to send someone onsite to check it out! Must check the results of that. In the meanwhile, they found a way for the return air to work…it will actually run through the joists, with the joists and the plaster forming the ‘pipe’ for the air. Apparently is works. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Late last week, the brickies started placing the bricks around the house… Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ And yesterday and today they started bricking the back: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The side Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The alfresco Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The front Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ We were going to have the cream (mushroom) colour bricks more in the front, but as it happened, the brickies were working today (very impressive being a public holiday in Melbourne) and I went past early in the morning and had a good chat with them. Great blokes! The were more than happy to move some bricks around for us. Even allowed me to lay a brick!! That’s building your own house. We also had a chat about the side of the garage. He mentioned that it would be more labour putting brick over brick so they didn’t have to go over the neighbour’s property. I said that it wasn’t an issue because I am already paying for it! I happened to have my contract at hand and showed him the line item. Quite impressed he was! My Build:https://forum.homeone.com.au/viewtopic.php?f=31&t=50541&p=772361#p772361 site start: 24/8/11 slab: 5/9/11 frame: 21/11/11 lock-up: 6/6/12 Re: Building a Sunnydale with Clarendon 77Nov 03, 2011 6:25 am glenlea29 progressing really well there katman our house didn't get any blue wrapping either ? its weird how we actually have our bricks up before the roof tiles must be a NSW thing I agree - wierd stuff. We did get some blue wrapping in sections. Mianly where we had the cladding placed. Our bricks were all done before roof tiling started. Makes more sense I think. Re: Building a Sunnydale with Clarendon 78Nov 03, 2011 8:17 am sorry to hijack this thread We optioned to go for no cladding ie replace cladding with brick FWIW's if you need to make any changes even during construction stage if they slap you with a $500-$1000 admin fee you can actually argue it and negotiate Re: Building a Sunnydale with Clarendon 79Nov 03, 2011 2:02 pm glenlea29 sorry to hijack this thread We optioned to go for no cladding ie replace cladding with brick FWIW's if you need to make any changes even during construction stage if they slap you with a $500-$1000 admin fee you can actually argue it and negotiate yep agreed. Mine wasn't allowed as we have the 2nd storey short of the 1st floor on one side. Hope that makes sense. have a few optiosn but all were expensive. Went with cladding. Re: Building a Sunnydale with Clarendon 80Nov 05, 2011 4:56 pm I would have liked brick all the way, however, we have cladding on the first floor across the front, on the side above the garage and half of the back - above the family room area. As rjg wrote, the garage section is above thin air! So, to provide the reinforcing steel that would be able to support the bricks we were told would be cost inhibitive and change the feel of the façade (which is why the rest of the front has cladding). Instead of the horizontal cladding that was offered, we went with blue-board and a rendered look. I notice Clarendon now have a special on that....oh well, swings and round-abouts! Insulation wrapping seems to be standard here in Victoria. I don’t know if there is a building reason as to whether you should do the roof or the walls first…but, in my amateur opinion, it is the frame that holds the roof, not the bricks. The frame and trusses may have a little bit of movement once the roof tiles are put on, so bricking after the roof is on may be easier to then make adjustments if required. Back to the build… Confirmed some insulations between the garage room and the first floor. The brickies have been working really hard, not quite finished the ground floor but are really close to having that done… Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Running some data cabling through the house, anyone got any thoughts on heights and positions? My Build:https://forum.homeone.com.au/viewtopic.php?f=31&t=50541&p=772361#p772361 site start: 24/8/11 slab: 5/9/11 frame: 21/11/11 lock-up: 6/6/12 It is Genneral stairs, but they won't deal with anyone off the street. They will only work with clients of project home builders. I tried to but some of these exact… 3 8765 The two 15mm holes are obviously not compliant. The Dept of Fair Trading would love to see this one! Do the gutters pool water after it stops raining? Although it's… 4 8767 |
