Browse Forums Kitchen Corner Re: Caesar stone join on island bench :-( 33Oct 06, 2011 4:03 pm Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Caesar stone join on island bench :-( 36Oct 07, 2011 10:44 am I think there a are a few issues here: The location of the join. Some say the best spot for a stone join is across a sick or cooktop as it means there is less physical area of join. Stone is also not an issue to join directly around wet area like laminate is The color and pattern of the stone. This stone seams to (from the photo provided) have a very light/feint variation. If it was heavily flecked or had a lot of variation (a busy look?) the the join may hide better, depending on the ability to match the pattern in cut ends The fact that the OP wasn't aware there would be a need for a join (more discussion below) Like I mentioned earlier, The builder didn't have to tell you , but they should have IMO, easier for all in the end and you get to make better informed decision. This places is also a great resource for questions to ask about all manner of building topics. The fact we (anyone except the OP) can go and see it IRL. It could look very different in real life under regular lighting conditions. I Find it very hard to forget that something is there if I don't like it (like a scratch on my car) My attention will always be drawn the that area and I will always find it You mention that the bench was an upgrade, but I get the feeling that it wasn't the stone you are talking about but the length of the bench? If this were the case and you got the stone as standard but the length of the bench was upgraded (extended) then I think it is very poor on the builders behalf they didn't inform you of the requirement for a join. Re: Caesar stone join on island bench :-( 38Oct 07, 2011 1:58 pm chrisandkate You mention that the bench was an upgrade, but I get the feeling that it wasn't the stone you are talking about but the length of the bench? If this were the case and you got the stone as standard but the length of the bench was upgraded (extended) then I think it is very poor on the builders behalf they didn't inform you of the requirement for a join. I believe the OP said the cat. 3 stone and the oversized stone bench tops were both upgrades. I don't think I would be happy with that join. Are there any cleaning type products available to clean up/help disguise joins in stone? Re: Caesar stone join on island bench :-( 40Oct 07, 2011 5:33 pm You can also clearly see that the join is closer from one end to the other. This is the difference between a quality stonemason and one that employs a labourer to do the job. Where I work this would not happen, all joins and measurements are triple checked before they leave the workshop. A bank is a place that will lend you money only if you can prove that you don't need it... Thankyou for your advice. We do have Caesar coming out and hopefully resolve the issue for us. 4 19528 DIY, Home Maintenance & Repair Are you going to have the frame exposed or are you cladding it with something. Usually if you are making an exposed frame you would use solid legs around 100x100 or… 3 7239 Well, it was the default we got with our deign, walking through the build last week felt ok, based on drawings on the floor, it is basically a metre, which is quite a big… 3 850 |
