Browse Forums Lighting + Lighting Design 1 Aug 18, 2011 1:50 pm Hi All, We are almost ready to start building, we have a block, and a design... and are just waiting for settlement. We think our design is great, but one thing that I know I'm going to get annoyed with is the lighting in the entry void! To give you an idea, you walk in the front door immediately into a double height void area, with stairs to one side up to the first floor. The display home just has downlights there. It looks OK, but then I wondered how would you change the lights if the bulb blew? That ceiling is double height, and no way I'm getting on a ladder that high. We thought of a chandelier, but it would have to be pretty modern, and I think you'd get the same problem with what to do when a bulb blows. My other thoughts are maybe to mount lights to the walls at either that shine up, about 3m off the ground. That would work from an access point of view, but I'm yet to find anything that looks cool enough Suggestions are welcome! EDIT: Picture of the Display Home below. Re: Help me light the void!! 2Aug 18, 2011 2:34 pm Trikcy ... wall lights would be the go ... I've seen some really cool "art deco" ones on here somewhere ... For info on our build: viewtopic.php?f=31&t=43093 Built the McLaren by Dechellis - slab down 22 Feb - handover 30 Aug 2011 - and gardens finished 9 Dec 2012!! Re: Help me light the void!! 3Aug 18, 2011 2:40 pm Step lights would be pretty nice. Wall lights on both sides of the front door, high up, would look good too. Newtown rebuild: https://forum.homeone.com.au/viewtopic.php?f=53&t=48977 Help me light the void!! 6Aug 18, 2011 5:30 pm Although our void is quite a bit smaller than yours, we are using a mix of LED wall lights and a Pendant/Suspension, switched separately. 6x LED Wall lights DSW111 with cool white globes mounted about 1800mm above floor height. http://www.cklighting.com.au/index.php?Product/index/id/42 Pendant/Suspension light http://www.mattblatt.com.au/Pendants/Replica-De-Lucchi-and-Ubens-Castore-Suspension-Light.aspx?p2979c4 Other suppliers where I have purchased some of our lighting from are: http://www.astrolighting.co.uk/ they do have a supplier in Melbourne. Ecc.com.au http://aboutspace.net.au/ very funky shop in Fitzroy, Melbourne Hope this gives you some inspiration! Building NBG Buckingham 320E Eastern Suburbs Melbourne Knockdown & rebuild Build startup 28th October 2010 http://buckingham320e-the4ofus.blogspot.com/ Not sure if that works? I was told the issue is the headspace clearance requirement on step 4. My builder is proposing shifting the beam 310mm towards the kitchen...I'm… 2 3044 To me, that's what it looks like: poor backfilling and/or compaction. The width is about 1000mm maybe. That conduit in the photo is for the NBN. The water is about… 4 9409 |
