Browse Forums Kitchen Corner Re: Pros and Cons on handle-less cabinets/cupboards please 5Aug 12, 2011 12:07 pm Check out our renovation in progress at http://www.ourdiydream.com Follow us on facebook http://www.facebook.com/ourdiydream Check out what we are 'pinning' http://pinterest.com/ourdiydream/ Re: Pros and Cons on handle-less cabinets/cupboards please 6Aug 12, 2011 1:21 pm Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Pros and Cons on handle-less cabinets/cupboards please 11Aug 15, 2011 7:28 pm http://lindeman28.blogspot.com - Our building blog Re: Pros and Cons on handle-less cabinets/cupboards please 12Aug 16, 2011 7:31 am Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Pros and Cons on handle-less cabinets/cupboards please 14Aug 16, 2011 9:51 am http://lindeman28.blogspot.com - Our building blog Re: Pros and Cons on handle-less cabinets/cupboards please 15Aug 16, 2011 10:48 am Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Pros and Cons on handle-less cabinets/cupboards please 19Aug 16, 2011 2:00 pm Darren Stewart We used the Aluminum section between drawers, it looks great too. That is a nice kitchen, think you get away with it because there is no base doors Like these? A kitchen I built for Amanda Taberra Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Pros and Cons on handle-less cabinets/cupboards please 20Aug 16, 2011 2:02 pm silversurfer Amazing looking kitchen, especially like the floating bulkhead over. Are your overhead cupboards full height and pull up or swing doors and do you have magnetic catches on them. They are acutally two cabinets one ontop of the other. The bottom timber grain cabinets are 330mm deep with lift up doors. The top white cabinets are 450mm deep also with lift up handles. There are lights in the bottom of the top cabinets that overhang the timber grain cabinets. (there not on in the photo) No magnetic catches. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com at most it will have a short lintel which could be moved up just below the ceiling or even above. Above means you need to patch the cornice and might need to deal with… 2 61800 You can really use anything you want the main consideration would be how it looks once painted/finished - or the look you want. Cabinetmakers use MDF because its cheap… 2 10614 Thanks mate. Yeah good points! Leaning towards Option 3 to get a bit extra space in the cabinets but not going too crazy high (and expensive). Would require a mini… 13 41220 |
