Browse Forums Feng Shui Windchime 2Jun 30, 2004 1:03 pm It is said that if your back and front door are in direct alignment money will flow straight in through the front door and then out the back door.
Do you have anything in the hallway, such as plants, furniture, pictures on the walls? Any of these could help slow the energies down. Re: Hallway 4Sep 30, 2004 3:18 am Hi Bella,
If you cannot use furniture to help slow down the energies you can use pictures or photo's on the wall. Next time you walk into a house with a long corridor notice how fast you walk and if you stop to admire any pictures etc, this is symbolic of the energies slowing down. Re: Hallway 8Nov 21, 2007 4:04 pm hi guys. i'm new to this forum and the topics are really interesting. especially for me and my wife (1st time home buyers).
we are building the langham and the master's bedroom's door opens up to the courtyard. so in effect, the bedroom door is facing the courtyard door. is this bad feng shui? please see picture. thanks in advance. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Hallway 9Nov 21, 2007 4:32 pm As far as I remember with feng shui if doors are in alignment you are letting the flow of energy out.
BUT…As far as design goes….I like your room, and couldn’t think of anything better than having a view to the court yard. It’s a great way to wake up of a morning looking out at the greenery. Give the feng shui a miss, your room looks great! It has potential for a stunning Master Bedroom space. I wish it was mine!! If you’re concerned about the energy flow, move the main hall door over to the right. Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Hallway 10Nov 22, 2007 7:42 am Feng Shui is more than just energy flow.
It's about connecting with nature in the right way, and that includes our rooms of solitude, bathing and living. So if you want to review how the shui of it fits, grab a book designed for the southern hemisphere and have a read. Steve Re: Hallway 11Nov 22, 2007 8:15 pm thanks guys for the tips.
thanks Michelle for appreciating our floorplan. we really want to make good use of the bedroom courtyard but not sure yet of what to put in it. we are also planning to move the sliding door to the ensuite side so the 2 doors don't face each other. any good feng shui book title that you guys would recommend? thanks. Re: Hallway 12Nov 22, 2007 8:22 pm I've found this book pretty easy to read for grasping the concepts, reasons why, examples etc.
"Feng Shui by Hemispheres" It explains the principles in a pretty easy manner and is designed to explain the southern hemisphere adjustments. ISBN 1 86476 266 7 Steve Re: Windchime 13Nov 22, 2007 9:11 pm Guest It is said that if your back and front door are in direct alignment money will flow straight in through the front door and then out the back door. My doors aren't arranged that way. However I am married............ SAME AFFECT! Ash. Re: Hallway 15Nov 23, 2007 2:20 pm Guest wrote:
Quote: It is said that if your back and front door are in direct alignment money will flow straight in through the front door and then out the back door. Ash Wrote Quote: My doors aren't arranged that way. However I am married............ SAME AFFECT! I could say more...... So I will. Like It's all about having common goals and discussing them together all the time. Steve Might cheaper to changer your idea of what makes a home, have you considered building a porch? 2 52627 at most it will have a short lintel which could be moved up just below the ceiling or even above. Above means you need to patch the cornice and might need to deal with… 2 61905 What? It's a lighting question, the control joint is only needed at 12m centres, a bulkhead or change of direction will suffice as a 'break' in the ceiling, just make… 8 9017 |
