Browse Forums Kitchen Corner Re: How big is your corner walk in pantry?? 3May 09, 2011 12:52 pm Deemaree Kyndylan Capers: viewtopic.php?f=36&t=46852 My blog: http://www.sufficientlysufficient.blogspot.com/ Re: How big is your corner walk in pantry?? 4May 09, 2011 1:01 pm 1.6x1.6. The house is not finished yet, but I love the size of the pantry. We have lots of cupboards, 3 pot cupboards. The island has lots of cupboards underneath also and the kitchen sink is not in the island bench, it has it's own area. Re: How big is your corner walk in pantry?? 5May 09, 2011 1:10 pm DeemareeOur last build was 1.5m x 1.5m-which stored the microwave plus some appliances and food. This house has a somewhat bigger pantry.....3.5 x 2mish...stores the freezer, microwave and every kitchen appliance I own (apart from the Kitchen AId stand mixer & coffee machine which live on the benchtop)-LOVE my pantry! That's what I wanted, but it just won't fit in So have had to fall back on a smaller walk in pantry and then a large appliance type cupboard as I am sick of having so many things out on the bench top.I think the last kitchen person allowed around 1 x 1.2 which I am thinking will be too small, especially if I need to get a little step or something in to get stuff from the top shelves (I am rather short!!) Re: How big is your corner walk in pantry?? 6May 09, 2011 3:31 pm Minimum external carcass dimensions should be 1000mm x 1000mm - this will give you a doorway that is wide enough to comfortably enter the pantry. If it doesn't have a base - i.e sits directly on the floor it shouldn't be a problem to keep a small folding step inside the pantry to make getting items from the higher shelves easier - there are quite a few discreet designs on the market. Another tip is to make sure you get some sort of lighting in there that won't put the goods you are looking for in your shadow. This can be activated by the door opening or a motion sensor. Cheers, Earl Re: How big is your corner walk in pantry?? 7May 10, 2011 7:56 am Strumer thank you so much for the info. Now to find a kitchen display place so I can actually see what a 1 x 1.2 pantry looks like inside. We won't be having a base so hopefully we should be right. Will definately be looking at a light in the pantry now. So you can get ones that turn on when the door opens? Does the kitchen person have to install that? Re: How big is your corner walk in pantry?? 8May 10, 2011 8:18 am We are having a square 2m x 2m pantry with a small sink in there. Will have 4 shelves and under bench cupboards. We plan to put some of our bench top appliances in there too. It will have a motion detector. Depending on if you want to use your pantry as a meal preparation area or not, can determine weather or not you will need a large pantry. We saw some massive pantries in some display homes, probably best for large families that also contains the fridge. __________________________________________________________________________________________________________________ All new built homes look like display homes... until the furniture goes in. Re: How big is your corner walk in pantry?? 9Jun 03, 2011 12:25 am Ours is approx 4mx1.8 ish (only working of rough figures) but its a walk through from the garage and is only for food as i dont think that the shelves will be wide enough for big pans etc but i might be able to get a few appliances on there. I think that you are better to get a bigger pantry as you will always find stuff to fill it, I am intending to keep the kids school bags in there (we walk through from garage), my handbag and pile of mags, water bottle/stand, step ladder, broom, dust buster etc this way i am hoping that my kitchen will be clean and clear of clutter. Jasmin Hickinbotham Belmont - modified Signed: February 2011 Slab should go down before 2012 My build thread https://forum.homeone.com.au/viewtopic.php?f=31&t=52310&p=799483#p799483 Re: How big is your corner walk in pantry?? 10Jun 03, 2011 10:28 am Ours is approx 4mx1.8 ish (only working of rough figures) but its a walk through from the garage and is only for food as i dont think that the shelves will be wide enough for big pans etc but i might be able to get a few appliances on there. I think that you are better to get a bigger pantry as you will always find stuff to fill it, I am intending to keep the kids school bags in there (we walk through from garage), my handbag and pile of mags, water bottle/stand, step ladder, broom, dust buster etc this way i am hoping that my kitchen will be clean and clear of clutter. I think step is actually talking about a corner pantry that is built into the kitchen rather than a seperate room. 1000x1000mm is the smallest you would want. Remember the external size against the wall determines the size of the door on the front. Dont make it to big as the shelves will start to bow. A mixture of fixed and adjustable shelves makes the pantry far stronger and more usiable. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Its usually the client who is bad at understanding the expectations set by the builder (as evidenced by the OP). A base price lock is not indefinite and is usually well… 3 8985 Having recently built, i would remove the double sink in the kitchen. With your butlers sink so close to the one in the kitchen you could either not replace it at all or… 1 2550 DIY, Home Maintenance & Repair Sometimes they’re leaking or just dumping too much water right at the base, and that makes things worse. You could even run a bit of piping or an extension to direct… 1 16263 |
