Browse Forums Windows & Doors Re: The doors in my place aren't standard size! 2Dec 31, 2010 9:27 pm You can get doors easily in 720 wide, however the height would be your issue. Is there anyway you could lower the door frame height? It would be easier to keep and paint the existing door though. Re: The doors in my place aren't standard size! 3Dec 31, 2010 10:19 pm 720 and 820 mm wide are standard widths. Not sure what the standard height is, but the doors may be able to be cut down. Demolition August 2009, Construction Started September 2009, Completed December 2010 Re: The doors in my place aren't standard size! 4Jan 02, 2011 1:15 pm standard door height is 2040. not to much of a problem. You will have to cut 15 from both top and bottom. Or better still cut 30 mm off the bottom. then knock out and replace the bottom rail with glue then clamp over night. Re: The doors in my place aren't standard size! 5Jan 02, 2011 6:23 pm B STAR standard door height is 2040. not to much of a problem. You will have to cut 15 from both top and bottom. Or better still cut 30 mm off the bottom. then knock out and replace the bottom rail with glue then clamp over night. Not my question, but I'm interested. Is the bottom rail part of the door? How would glue form a proper base for a door. I'm obviously missing something. Demolition August 2009, Construction Started September 2009, Completed December 2010 Re: The doors in my place aren't standard size! 6Jan 02, 2011 9:06 pm You 'glue' a new bottom rail in place of the one that has been cut-down (removed) Re: The doors in my place aren't standard size! 8Jan 02, 2011 10:54 pm go to a place that specialises in doors and get the closest fit you can find. It may need to be trimmed down but there is a bit of leeway with doors. It's very unusual to get a door and have it "fit" perfectly, so you would just get the door hung and fitted by carpenter who can skim it to fit properly and hang it and generally places that sell doors offer this service, just take your door dimensions with you when you go to buy. Re: The doors in my place aren't standard size! 9Jan 03, 2011 1:27 pm piscean go to a place that specialises in doors and get the closest fit you can find. It may need to be trimmed down but there is a bit of leeway with doors. It's very unusual to get a door and have it "fit" perfectly, so you would just get the door hung and fitted by carpenter who can skim it to fit properly and hang it and generally places that sell doors offer this service, just take your door dimensions with you when you go to buy. Should the trimmed edge be smooth or have patchy appearance? Demolition August 2009, Construction Started September 2009, Completed December 2010 Re: The doors in my place aren't standard size! 10Jan 03, 2011 8:57 pm If done properly it should be smooth casa. Most doors need a bit of skimming in places to fit the frames properly and allow for flooring/carpets etc but you wouldnt notice it. Re: The doors in my place aren't standard size! 11Jan 03, 2011 8:59 pm Mine a poor along the edge that has the latch in, if you now what I mean. That is, the outside 35 mm wide bit. Demolition August 2009, Construction Started September 2009, Completed December 2010 Re: The doors in my place aren't standard size! 12Jan 03, 2011 9:53 pm it sounds like they were a bit lazy then, they should have sanded it up smooth before painting/putting finish on - esp with that exposed edge that you see when the door is open. Okay sorry silly me, my wife has solves the mystery for me. It’s because the labels on the ports are all wrongly positioned by the builder hence it confuses me. 2 1486 Use a product like Equisol's Vitalise to clean the deck then coat with a penetrating timber oil. It will look 10 years younger and add value to your home. Visit for… 1 16256 |
