Browse Forums Ideas Box 1 Mar 05, 2007 2:30 pm When replying to posts, the font is very small and hard to see.
Any chance this can be made the same size as the font in the rest of the forum please? A darker colour would be nice as well. Otherwise, this is a fantastic forum. Great to see the amount of interesting daily posts. Re: Font is too small in edit mode 2Mar 05, 2007 7:36 pm Bud977,
What I do is start the response in the edit box, then cut and paste it to Word (or similar). Here you can see it properly. And spell check it, which is very handy. Once you're odne, just copy and paste it back. This has another added advantage. If you lose your internet link between starting the post and pressing the Submit button then you've lost all your hard work. However, if you have the response in Word you just go back and cut and paste it again. Copy and pasting from Word is the way to go. Cheers, Casa Re: Font is too small in edit mode 3Mar 05, 2007 8:13 pm Hey Bud & Casa,
Thanks for your suggestion. Test it now, and see if this is more what you're after. Re: Font is too small in edit mode 6Mar 06, 2007 8:19 am 10 out of 10 homeone.
Very quick off the mark & shows how well managed & run the forum is. Peter Clarkson - AusDesign Australia www.ausdesign.com.au This information is intended to provide general information only. It does not purport to be a comprehensive advice. Not sure if that works? I was told the issue is the headspace clearance requirement on step 4. My builder is proposing shifting the beam 310mm towards the kitchen...I'm… 2 3086 It will be neat but you won't have much freeboard. At least they are not weep holes. Are you in a high intensity rainfall region? The regulatory slope is only required… 3 8804 Firstly, if your house is still under builder's warranty (10 years in Victoria) you should have no need to crawl into roof space but let the builder handle it, unless you… 3 5913 |
