Browse Forums Building A New House Re: Optimal size bedrooms 4Aug 09, 2010 1:35 pm mmm....donuts Homer Simpson 1956- Links: Site Costs Ready Reckoner | H1 Addiction Medical Advice | Château TDL: The Backyard Re: Optimal size bedrooms 6Aug 09, 2010 2:06 pm Timeline Aug 08-Land Mar 09-Demo/Titles Sept 10-Handover No1 Sept 11-Handover No2 April 12-Sold No2 Aug 14-Land/Demo Jan 15-Slabs viewtopic.php?f=31&t=25736 Re: Optimal size bedrooms 8Aug 09, 2010 2:28 pm mmm....donuts Homer Simpson 1956- Links: Site Costs Ready Reckoner | H1 Addiction Medical Advice | Château TDL: The Backyard Re: Optimal size bedrooms 12Aug 09, 2010 3:38 pm my new build thread- Ben Trager https://forum.homeone.com.au/viewtopic.php?f=31&t=89826 my switch build thread (2011) https://forum.homeone.com.au/viewtopic.php?f=31&t=36569 Re: Optimal size bedrooms 16Aug 09, 2010 8:22 pm Deemaree Kyndylan Capers: viewtopic.php?f=36&t=46852 My blog: http://www.sufficientlysufficient.blogspot.com/ Re: Optimal size bedrooms 17Aug 09, 2010 8:33 pm My current house is a bit on the small side and my master bedroom is 3.3 x 3.1 (internal) and thats big enough for a queen and 2 bedside tables. Personally I think much bigger than that is a waste for minor bedrooms, I think my new place has the 2 minor bedrooms (with the robes external under the eaves) about 3.5 x 3.5 and the master a bit bigger at 4.5 x 4.5 which I reckon is near enough spot on - but others may have differing needs than I do. Re: Optimal size bedrooms 18Aug 09, 2010 11:55 pm Our 3 other bedrooms not including ours is 3x4 and I think thats quite large Re: Optimal size bedrooms 19Aug 10, 2010 12:08 am I'm building at the moment and the 3 minor bedrooms are 3x3.8, 2.9x3.8, and 2.7x4.0. I'm a little concerned about the 2.7x4.0 (which will be the guest room) becaue of the layout, but the other two for my two boys I think will be plenty big enough (they look big with double beds in them in the display home). There is also an activity room between the two boys rooms. Re: Optimal size bedrooms 20Aug 10, 2010 12:25 am joles royalblue I think for bedrooms other than main bedroom, its best to have a nominal width of 3.65m. (This allows for full width carpets or floorcoverings with minimal wastage. Then the length can be as much as you can make it. If I were planning, I'd make it about 4.2m long. This would be a nice size of 15.33sq/m. But of course, it depends on how the overall floorplan works, and where you need more room. 3.65 x 4.2 for minor bedrooms? Pretty unrealistic in the current housing climate unless it's a custom build and $$$$ and size isn't an issue. If kids have to use their bedrooms as their play area as well, then size is more important, but if they are purely for sleeping, then the space is definitely better used somewhere else. You make some good points there Joles, and others' input as well. The original question was "what are optimal sizes" so I offered what I think is optimal. Sure, it may be unrealistic, but it is optimal! And although some may choose other floorcoverings than carpets, a nominal width of 3.65m makes a lot of sense. Whether its a length of 2.7m, 4.2m, more or less, having that width is a good standard. Ash. Hi, Have fun, remember bedrooms should feel relaxing and inviting, the last space you see before sleep and the first you see when you wake up. Make sure it makes you… 6 16572 All sorted guys. Just needed to buy a blade with the correct bush. Dunno how to delete this post, can't find any help file. Cheers. 1 3891 Current door width is approx 2700, looking to have double doors fitted 820-820. What size does the frame need to be before door jamb? Thanks 0 3942 |
