Browse Forums Lighting + Lighting Design Re: Lights flickering when off! 13Jul 02, 2010 9:26 am The capacitor in the globes might still be holding a change that hasn't dissipated properly the cheaper globes tend to flicker I've noticed.
Re: Lights flickering when off! 14Apr 30, 2014 8:39 pm it's normal, happening to our house as well. we've got clipsal saturn for entire house the sparky said CFL won't work, but my LED also won't work, they all flicks. he found a solution by rewire the lightswitch, it works, no more flickering however, it won't work on 2-way+, only 1 way. he is stilling thinking what he can do about it. 7.5M Dual Frontage terrace @ lightsview SA /viewtopic.php?f=31&t=58754 moved in - April 2014 furnitured - August 2014 home theatre - September 2014 Game room - December 2013 moved in - 09 April 2014 Re: Lights flickering when off! 16May 01, 2014 2:48 am the blue led suppose to be blue when in the off position so people can see it in the dark. like what i said, the sparky found a solution for the 1-way switch, but still working on 2-way. i will ask him to try to use Clipsal 31 CAP Capacitor Load Correction to see if it can fix the problem 7.5M Dual Frontage terrace @ lightsview SA /viewtopic.php?f=31&t=58754 moved in - April 2014 furnitured - August 2014 home theatre - September 2014 Game room - December 2013 moved in - 09 April 2014 Re: Lights flickering when off! 17May 13, 2014 9:28 pm frozenkuku the blue led suppose to be blue when in the off position so people can see it in the dark. like what i said, the sparky found a solution for the 1-way switch, but still working on 2-way. i will ask him to try to use Clipsal 31 CAP Capacitor Load Correction to see if it can fix the problem ...huh? It's because he's wired the neutral of the LED through the load rather than to a neutral. Re: Lights flickering when off! 18May 14, 2014 12:20 am You can resolve the fault. It is due to those specific switches and the fact your sparky more than likely did not have a neutral at the switch and wired them accordingly (which is fine, but not ideal due to this case). If your switches have conduits in the wall, all you need to do is have a neutral to each switch and wire them all as per the specification. I've heard of this happening so every time I wire these up I ensure there is a neutral present. Otherwise, you'll have to ditch the idea of your blue light on ur switch in the arrangement you currently have it (light off/led on) Re: Lights flickering when off! 19May 14, 2014 12:22 am frozenkuku the blue led suppose to be blue when in the off position so people can see it in the dark. like what i said, the sparky found a solution for the 1-way switch, but still working on 2-way. i will ask him to try to use Clipsal 31 CAP Capacitor Load Correction to see if it can fix the problem Rather than using those, there is a fairly simple wiring diagram I have that will fix it. It just involves running another twin between the switches. Re: Lights flickering when off! 20May 14, 2014 10:35 am Super Nes frozenkuku the blue led suppose to be blue when in the off position so people can see it in the dark. like what i said, the sparky found a solution for the 1-way switch, but still working on 2-way. i will ask him to try to use Clipsal 31 CAP Capacitor Load Correction to see if it can fix the problem Rather than using those, there is a fairly simple wiring diagram I have that will fix it. It just involves running another twin between the switches. Please upload this, I'm curious as to how this would be possible So I'm just reading up on this ecosystem of lights. I'm planning on putting deck lights along the outside edge of a large deck. Will need about 3 packs (18 lights) plus… 0 23420 Which ceiling hook to use to hang Xmas lights under Eaves in 1st floor in 2 storey façade (no… 0 1501 1 3497 |
