Browse Forums Building A New House Re: Are these weep holes in the correct level? 3Mar 12, 2008 12:39 pm I dont know whether this will help. My brickie did not put any weepholes in our garage wall. He said the weepholes wont be needed there as there were no gypsrock on the internal side. Re: Are these weep holes in the correct level? 4Mar 12, 2008 12:58 pm Hi Allan,
Is the garage floor level above or below the weep holes? If the garage floor level is the same level as the slab under the porch, you are going to end up with water inside the garage if you get a lot of water from rain or sprinklers hitting that brick wall. Water will seep down through the bricks (the bricks are porous) until it reaches the slab (minimally porous). When it reaches the slab, the water will try to drain out via the slope of the slab - weepholes make it drain faster by removing obstacles. If the slab on the outside and inside of a wall are the same level, you'll end up with water exiting the bricks on both sides of the wall (imagine the brick wall as the centre of a puddle). If the garage has a higher floor level, the water will exit the bricks on the outside only. I don't know whether this construction is outside the building code but this process was explained to me by someone whose neighbours had their houses done by "budget" builders who didn't use any sort of brick course step down on any of the garage walls. They were all complaining of garage flooding from sprinklers. Cheers, Jamie Re: Are these weep holes in the correct level? 5Mar 12, 2008 1:21 pm Just to clarify: our garage floor level is about 3 to 4 bricks lower than the porch slab level.
My understanding is: 1) using my supervisor's terminology: for "habitable" areas like living room, bed room, ...etc, the inside ground slab is at least 1 brick high and there's a flashing installed between the frame & brick wall to allow any rain/water trapped inside to escape. 2) For "inhabitable" areas like garage, there's only single brick with no flashing or other stuffs installed. And during heavy rainy period, it's possible to get some water leaked through/inside the brick walls. And yes, for our house the brick wall on the garage side is only single brick without any flashing or other stuffs installed. I checked other side of the garage wall, and there are a few weep holes been installed as well. But I am still not satisfied with supervisor's "this is normal" comment. I guess in the worst scenario, I will just ask our inspector during our final hand over inspection and see what he says. Re: Are these weep holes in the correct level? 7Mar 01, 2010 11:04 am LexSo, should there be weep holes in garage or not, for a garage that is plastered internally? Hi Lex, Yes, there will still be weep holes in garage. As the floor level of garage is lower than the the house, you will notice the area that's plastered ends at the same floor level as the huose, it shouldn't go down to the floor level of the garage. Otherwise if there's any water in your garage, your plaster walls and other timber stuffs will be damaged. Re: Are these weep holes in the correct level? 8Mar 01, 2010 6:01 pm Hi Allan, So you changed your name?? That's why I couldn't find your posts recently ... Anyway, welcome back, it's nice seeing you here !! I love your blog (thanks for the weephole answer!) My signature is distracting people from my wise posts ... Re: Are these weep holes in the correct level? 9Mar 01, 2010 11:46 pm After moved in more than 12 months, I guess everything sort of cooled down a bit. Focusing more on work, kids and other stuffs. Haven't visited the forum for a while... For my blog, try the "google search" function or the "labels" to help with searching on any topic you are interested. Or drop me a line by email or post some comments, I will try to get back to you within a few days. Weep holes are where they are because they are drain holes. You also have to think of the DPC that prevents rising damp, the cause of efflorescence. 1 21007 I'm arranging renovations to be performed on my house, which involve replacing the kitchen and laundry, adding a new ensuite, removing a non-structural wall and raising a… 0 94430 Yeah that little # note sounds like the catch. If you paid for 2400mm though, I’d flag it with the builder now before it’s too late. Easier to sort while they’re… 2 24198 |
