Browse Forums Interior Decorating Lounge Re: Paint q's 2Feb 27, 2008 9:45 am Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Paint q's 3Feb 27, 2008 9:47 am Sounds like you have a great base to work with, why not dress it up with art, furniture or ornaments? If you start painting colours you may limit your market, although neutral is good.
Buy a few nice pieces that you can take with you to your new house Paula Re: Paint q's 4Feb 27, 2008 12:00 pm Thanks guys - great advice as usual!!
There are a few small marks on the walls which I can't seem to get off with elbow grease Do you think its best to give the walls a fresh paint with white then? Are people that fussy? Will it just be a a waste of time/money giving it a repaint? i was thinking of just painting over the marks - not sure if it will look completly weird tho Re: Paint q's 5Feb 27, 2008 12:21 pm Quote: There are a few small marks on the walls which I can't seem to get off with elbow grease Better than using axle grease Do you have any matching white paint? It's worth a go as a touch up job, or if you have none take a sample of paint to the shop and have it matched - it might not show up as a patch - and if it does - then you may have to redo that wall, and maybe the other walls in the room so it looks all the same. And I thought - leave ital the white colour too - but left it for Mish and Paula to say White is also good in case the new owner is buying as an investment, as white is an easier colour to rent out - tennants can put up a few paintings etc and the place looks customised to their tastes. Steve Re: Paint q's 7Feb 27, 2008 12:58 pm Quote: Just wondering though - how do I get a sample of the paint to get colour matched - wrip a chunk off the wall? Yep Normally there is something you can rip off a bit of flaking paint or something. Inside a cupbaord their may be a bit of trim you can take off, take it in then put it back in place afterwards. Photos sometimes work. Steve [/quote] Re: Paint q's 8Feb 27, 2008 8:02 pm I’m with Steve; just do a quick patch up. But make sure you do the prep well or it will be seen.
There are so many whites out now, hard to tell which one you might have. If it’s not a pure white, you can slip a piece of paint off the wall where the chips are and take it to a Dulux paint shop, they have a spectrometer; it will be able to match the paint exactly to the chip. Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Paint q's 9Feb 28, 2008 7:52 am Thanks guys!
I will get onto it this weekend - I was just going to use sugar soap to clean the walls and then a roller of the paint - they are quite faint marks so I'm hoping one coat will be enough... If all else fails I'll just hire a painter Thank you. That is really helpful. Once we get the place done and passed for OC we can upgrade in the future once we get back on our feet and not paying mortgage and rent. 4 6268 DIY, Home Maintenance & Repair Hi there, I just recently received my new house from my builder. We handed the house to another company to deal with the… 0 10274 DIY, Home Maintenance & Repair Grind texture and paint off at blister up to top of fence Will see damp cement render 5 7510 |
