We are in Perth have purchaced a block approx 8klms from the coast, a south (front) facing home will be built on the property. South facing blocks in Perth IMO rated as one of the most prefered facing such that you have a North East Alfresco/patio.
So we have designed a home with a 16m staight passage which all the bedrooms run along and at the end of the passage we have a awning window.
We will mass plant on the western side with low growing plants, and some taller plants 2m directly in front of the windows to shade the Western windows, which will convert carbon dioxide to oxygen, oxegen being a light gas will rise and cause air movement (upward) and this creating a cooling effect, and with the 3pm fremantle doctor will force the cooling air into the Western side windows, air being forced into western windows and air passing the northern awing window drawing out the air from the home and cooling down the home.
Foil sarking between the colorbond roofing and battens and batts on the ceiling.
Fingers cross we should not need any form of mechanical air-conditioning.
missed anything?
