Browse Forums What's New 1 Nov 20, 2009 2:28 pm Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: Recessed Power Points 4Nov 25, 2009 2:39 pm Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: Recessed Power Points 6Nov 25, 2009 7:38 pm Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: Recessed Power Points 16Mar 10, 2010 11:14 am Our house thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=18335 Re: Recessed Power Points 17Mar 11, 2010 1:31 pm Nathan SteelFab pinky And available at Bunnings...... Surely you need to be an electrician to install these? Anyway, they are a great idea, it's just a shame they are so bulky, that flange around the outside...does it really need to be that big? I can think of a few places that I will need them down the track. Nathan I thought that too initially. But no - you do not disconnect any of the actual power point - it just sits wholly in the frame. My Dad is a retired eleco so I was thinking I would have to get him over but once he looked at them he said that DH could go ahead and install them without any issues. Now cutting through the tiles to install one behind the tv in the bathroom on the other hand was a dead set nightmare!! Some things are worth waiting for. Re: Recessed Power Points 18Mar 12, 2010 7:36 am As soon as you said anything about cutting tiles I knew that there would be problems. If I had to cut a tile I would end up with a pile of dust in no time. haha Re: Recessed Power Points 19Mar 12, 2010 11:04 am Nathan, must say DH did a very good job. We just did the lots of little drill holes around the perimeter then gently tapping with a hammer until it cracked inside the cuts. I was a nervous wreck - the only time I rued the decision to have the bathroom tiled to the ceiling!! Some things are worth waiting for. Re: Recessed Power Points 20Mar 16, 2010 4:01 pm GSK I'm using these from Monoprice: http://www.monoprice.com/products/produ ... 1&format=2 Clipsal have a replacement power point that suits Aussie plugs. The total cost is around $40 per unit completed, and delivered to Australia. The advantage of this is that it's small and cables can run directly through the hole. I'm using HDMI & Cat 5 cables throughout most of the house and I didn't want to have a heap of connectors so now I can just run the cables direct. I've often wished that these Monoprice wall plates were available with an Australian outlet, I never thought that it was possible to replace the outlet by itself! Which model Clipsal product are you using? Does it fit exactly right? If you're referring to Eufy homebase, then just put a switch between a datapoint and put the homebase elsewhere near another device in your home unless you want teh… 9 14106 Would also like an opinion from anyone that has used xcem over hebel for floors. Thanks 1 15393 2 16238 |
