Browse Forums Outdoor Living Re: Pergola to match original roofline pitch 7Jan 10, 2010 8:49 pm Check your local councils website for the regulations. Will you be using timber or steel? Steel requires less structure but is more expensive yet easier to put together. I think I have a pic somewhere of what you might be speaking of? I found it the other week. Here it is Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Pergola to match original roofline pitch 8Dec 26, 2010 7:05 pm This is what I plan on doing with my place early next year. Mine will be only approx 2x7 metres, and will mainly be used as a semi enclosed tool area. My home is raised, so i will be starting my pergola approximately 30cm below the existing eave and continuing on the same pitch. It will be crossing above a dining room window so I will be using the most transparent roofing material possible to minimise any problems with lighting. The home is a brick veneer and I will be using posts on one side of the pergola, and bolting the other to the brickwork. I would like to keep this post active, so I will upload a photo of the house, with a rough MS paint drawing the how the pergola will sit. If you find any other info or links on how others have gone about doing this please post in here as i would be very interested in seeing how those who have gone before have done it. Re: Pergola to match original roofline pitch 9Dec 26, 2010 7:54 pm I am sure I have seen this type of roof many times. Basically short risers come from the top-plate through the roof, then the new roof follows the pitch of the existing roof. It is a good look, provides good fall (ie drainage), should allow air circulation keeping it cool in summer, is water tight and should be economical. I often walk past a house where this type of addition has been done and it looks awesome. Sorry I can't get a photo for you but you can see it on google earth at 33degrees 45'47.40S 151degress 00'42.45E. I say go for it Building an Eden Brae Saville 27 http://karry327.blogspot.com/ Building thread https://forum.homeone.com.au/viewtopic.php?f=31&t=44247 Re: Pergola to match original roofline pitch 10Dec 26, 2010 9:24 pm My parents have this sort of pergola down the full length of their house ... looks fantastic. Only downside is the rain does come in if it's blowing that way and they have gutter guard on the gutters, so if the rain is only light it's not enough to 'push' through the mesh of the gutter guard and runs straight over and drips onto the deck. But they still love it and are very happy with it. We wanted to do the same, but as we're in a W50C wind rating area, we are only allowed to attach the pergola under the gutter, so rules that design is ruled out for us. ~ trying to build our dream home by the sea ~ Re: Pergola to match original roofline pitch 11Dec 27, 2010 9:03 am karry327 I am sure I have seen this type of roof many times. Basically short risers come from the top-plate through the roof, then the new roof follows the pitch of the existing roof. It is a good look, provides good fall (ie drainage), should allow air circulation keeping it cool in summer, is water tight and should be economical. I often walk past a house where this type of addition has been done and it looks awesome. Sorry I can't get a photo for you but you can see it on google earth at 33degrees 45'47.40S 151degress 00'42.45E. I say go for it Can you please advise of the address? I can't get google to recognise those instructions. I would love to have a look! Re: Pergola to match original roofline pitch 12Dec 27, 2010 2:24 pm The address is Lara Cres, Baulkham Hills, NSW. Look at the first three houses in the street, it is the middle house between the start of the street and firetrail access. The extension is the light covered roof with two skylights. Not much to see from above but it looks good when i walk past it. Building an Eden Brae Saville 27 http://karry327.blogspot.com/ Building thread https://forum.homeone.com.au/viewtopic.php?f=31&t=44247 Hi, I am planning to select San Selmo reclaimed original for the fascade of my build. I have seen many photos on line of the brick varying from a rustic to a neat finish.… 0 4877 Hello! I've alfresco pitch of 3 degrees sitting just below the highlight window. Need advice on below: 1. Will the 3 degree pitch be ok to drain the rain water? The roof… 0 4534 Why don't you call and talk with someone at the town planning in your council? 1 2283 |
