Browse Forums Landscape & Garden Design 1 Dec 28, 2009 3:26 pm 'A bottle of wine contains more philosophy than all the books in the world.' Louis Pasteur Vegie garden: viewtopic.php?f=19&t=27637&start=0 My Backyard Adventure Re: My vegie garden plan 3Dec 28, 2009 4:00 pm Land settlement 4 May Building contracts signed 27 July Slab pour 26 March Frame started 10 May Bricks start 31 May Roof & Gutters Start 31 May gyprock 1 July Kitchen & cabinets/tiling 19 August Second fix plumbing 15 September Second fix electrical 22 September PCI 28 September viewtopic.php?f=31&t=29155 Re: My vegie garden plan 4Dec 28, 2009 4:57 pm 'A bottle of wine contains more philosophy than all the books in the world.' Louis Pasteur Vegie garden: viewtopic.php?f=19&t=27637&start=0 My Backyard Adventure Re: My vegie garden plan 6Dec 29, 2009 9:23 am 'A bottle of wine contains more philosophy than all the books in the world.' Louis Pasteur Vegie garden: viewtopic.php?f=19&t=27637&start=0 My Backyard Adventure Re: My vegie garden plan 8Dec 29, 2009 9:43 am 'A bottle of wine contains more philosophy than all the books in the world.' Louis Pasteur Vegie garden: viewtopic.php?f=19&t=27637&start=0 My Backyard Adventure Re: My vegie garden plan 9Dec 29, 2009 9:52 am Whilst I think you can avoid the cement, IMO you probably can't avoid bonding the bricks together. However you could use construction adhesive as shown in http://www.ehow.com/how_5266272_build-g ... ement.html . The pipe hanger strap is a perforated galvanised strap which you can get from Bunnies in the plumbing section (lots of people use it for tieing inflow pipes to water tanks). The simple purpose of the hanging strap is to create an even gap between the bricks, and because it's non-compressible, stops the building adhesive from extruding out from between the brick and there not being enough goop between the bricks for bonding. So materials are pretty cheap...some gravel etc to level out the base, construction adhesive for bricks, perforated straps, and an adhesive gun. If you have a spider phobia you may want to cap the bricks...spiders will love the holes in the top of the bricks... As far as star pickets go, you can get different sizes from Bunnies from about 300 mm up in 300 mm increments...a piece of advice based on bitter experience, by the star picket caps whilst you are there... Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Two reasons...the ends of the pickets get bashed around a bit and the jagged bits of metal can grab your lower legs...and the caps will protect you from picket ends at eye level. Serving suggestion only... Cheers, Mike mmm....donuts Homer Simpson 1956- Links: Site Costs Ready Reckoner | H1 Addiction Medical Advice | Château TDL: The Backyard Re: My vegie garden plan 10Dec 29, 2009 10:06 am Hrmmmmm any idea on how difficult/expensive would it be to make it out of timber, so say a 1.2x1.9m bed that's 50-60cm high? keeping in mind that my brother is an apprentice chippy it wouldn't take him long to knock them up 'A bottle of wine contains more philosophy than all the books in the world.' Louis Pasteur Vegie garden: viewtopic.php?f=19&t=27637&start=0 My Backyard Adventure Re: My vegie garden plan 11Dec 29, 2009 10:30 am I've only seen the veggie garden once but i think its 4 or 5 bricks high. no bonding. Don't like the look of that hole. Seems the bunnies are busy doing some serious digging. If you laid chicken wire as a base before adding the soil to your raised veggie garden it might deter them but then of course after a while the wire would rust/ deteriorate. But at least it would maybe stop the bunnies digging up into your patch. Blog http://wherethehearthis.blogspot.com/ Build https://forum.homeone.com.au/viewtopic.php?t=6634: Yard https://forum.homeone.com.au/viewtopic.php?f=19&t=27687&p=378401#p378401 Re: My vegie garden plan 12Dec 29, 2009 10:37 am I'm hoping that once I make my backyard more secure the rabbits wont be able to get in - by secure I mean finishing all the pathways etc up to the fence so that there are no longer any gaps for them to get in through and also maybe putting some wood up under the fence from the outside 'A bottle of wine contains more philosophy than all the books in the world.' Louis Pasteur Vegie garden: viewtopic.php?f=19&t=27637&start=0 My Backyard Adventure Re: My vegie garden plan 13Dec 29, 2009 10:53 am Hrmmmmm any idea on how difficult/expensive would it be to make it out of timber, so say a 1.2x1.9m bed that's 50-60cm high? keeping in mind that my brother is an apprentice chippy it wouldn't take him long to knock them up Keep it to 300 mm increments to get standard size timbers...so 1.2 x 1.8...chippy will be able to knock it pretty quickly. As an idea: Redgum Sleepers...1.8 m x 200 mm high x 50 mm about $15 per length Redgum Sleepers...1.8 m x 200 mm high x 75 mm about $21 per length Treated Pine Sleeper...1.8 m x 200 mm high x 50 mm about $11 per length Treated Pine Sleeper...1.8 m x 200 mm high x 50 mm about $16 per length Add 10% for wastage...probably $50 - $75 for hardware, screws, gal brackets. You can work on the per metre price based on that...I'm sure people can give you prices local to home. Oh and be prepared now for the philosophical debate of treated pine versus non-treated.... mmm....donuts Homer Simpson 1956- Links: Site Costs Ready Reckoner | H1 Addiction Medical Advice | Château TDL: The Backyard Re: My vegie garden plan 14Dec 29, 2009 11:02 am Thought of one of these... http://cgi.ebay.com.au/Metal-Raised-Gar ... 45f0071389 mmm....donuts Homer Simpson 1956- Links: Site Costs Ready Reckoner | H1 Addiction Medical Advice | Château TDL: The Backyard Re: My vegie garden plan 15Dec 29, 2009 11:09 am they look relaly good TDL. I have swung between them, doing temp straw bale walls and maybe brick walls. can't decide. We also have some other friends who have those metal ones and asked them what they thought of them and they think they are terrific. it all comes down to cost, gardens space and whether you want the flexibility of changing the bed size. Re: My vegie garden plan 17Dec 29, 2009 12:07 pm No they aren't . Can't think why but I ahve actually seen them on display. the reason why they aren't sharp escapes me atm. I think they have a rolled over edge or something. Maybe just blunted so they aren't razor sharp. if it worries you then you can buy cheap hosing slice it open and fit it over the top edge. as a capping. We used to have a raised veggie bed done with half pine (treated) logs. Was fine until the buffalo lawn and some some Kikuyu started invading at the corners. If you plan on very raised beds then don't make them wider than you can reach. Unless you fancy always having to climb up into them to get your veggies. Re: My vegie garden plan 18Dec 29, 2009 12:19 pm With regard to the bricks, just take one out. You can do that by using a big screw driver and a hammer and in the middle of the chosen brick, smack it and it will crack, then you can crack it a few more times and flick out the broken bits. Pop some gravel in those spots if you want. Cut the pickets in half. You would need a grinder for that, but they are fun I reckon As for kex's idea of the pickets to be used to hold shade cloth, fantastic thinking ![]() You can use PVC irrigation pipe and cable ties to construct a make shift or semi permanent shade structure and get a better quality crop ![]() Re: My vegie garden plan 19Dec 29, 2009 12:55 pm to_do_listThought of one of these... http://cgi.ebay.com.au/Metal-Raised-Gar ... 45f0071389 I would love to get 4 or 5 of them! I've seen them before but I am trying to do this on the cheap side of things although that cost on that ebay auction is similar to what wood would probably cost I think With regard to the bricks, just take one out. You can do that by using a big screw driver and a hammer and in the middle of the chosen brick, smack it and it will crack, then you can crack it a few more times and flick out the broken bits. Pop some gravel in those spots if you want. Cut the pickets in half. You would need a grinder for that, but they are fun I reckon As for kex's idea of the pickets to be used to hold shade cloth, fantastic thinking ![]() You can use PVC irrigation pipe and cable ties to construct a make shift or semi permanent shade structure and get a better quality crop ![]() If was putting a star picket in each set of bricks I don't think I would be able to get into the garden bed! Could I use liquid nails or anything else to make the bricks stick together? Maybe I should just use cement lol!! This is starting to give me a headache now... too much but it's good to get it right before I start'A bottle of wine contains more philosophy than all the books in the world.' Louis Pasteur Vegie garden: viewtopic.php?f=19&t=27637&start=0 My Backyard Adventure Re: My vegie garden plan 20Dec 29, 2009 5:14 pm Are they sharp along the top edge? Nope...rolled edge. mmm....donuts Homer Simpson 1956- Links: Site Costs Ready Reckoner | H1 Addiction Medical Advice | Château TDL: The Backyard Looking at those pics, the main problem is water pooling because the yard’s too flat and shaded. If you just lay pavers or pebbles, the water will still sit there.… 1 13653 If I may venture an opinion, which is only an opinion and not DEFINITELY accurate for everyone ... but I don't think there is a single correct answer to your question. If… 1 4021 Hi guys, I'm planning to build a garden shed along one side at the back of my house. The available space is 1.6m wide, and I'm… 0 62130 |
