Browse Forums Flooring & Floor Covering Re: Best carpet for children's bedrooms 4Sep 29, 2009 5:11 pm Build thread: viewtopic.php?f=31&t=34120 Handover 23 Dec 11 Squatting 21 Dec 11 Fixed 12 Oct 11 Plastered 31 Aug 2011 Framed 7 June 2011 Site Start 7 Feb 2011 Land Titled 18 Jan 2010 Land Deposit 25 Jun 2009 Re: Best carpet for children's bedrooms 5Sep 29, 2009 8:52 pm cheers Col Nation For information on caring for wool and other carpet and upholstery go to www.woolsafe.com.au Re: Best carpet for children's bedrooms 10Oct 09, 2009 6:24 pm I was recently told by a couple of local carpet retailers to avoid WOOL carpets especially if I have my dogs inside because "wool has no natural protection against stains" (must change when it comes off the sheep's back) It was suggested by a couple more that I use solution dyed NYLON twist carpet. There was a nylon plush which is the same only with a shorter cut pile. I eventually chose 'Redbook' carpet and was told by the installer to "never clean the carpet in a circular motion" -- which I guess rules out the 'Electrodry' cleaning method and not to use steam cleaning because "all carpets are scotch-guarded when they are made, once they are steam cleaned this is removed necessitating cleaning much more often" -- unless ofcourse you have the carpet re-scotch guarded at considerable expense after the first clean. Arfur Re: Best carpet for children's bedrooms 11Oct 16, 2009 3:41 am Uncle Arfur I was recently told by a couple of local carpet retailers to avoid WOOL carpets especially if I have my dogs inside because "wool has no natural protection against stains" (must change when it comes off the sheep's back) It was suggested by a couple more that I use solution dyed NYLON twist carpet. There was a nylon plush which is the same only with a shorter cut pile. I eventually chose 'Redbook' carpet and was told by the installer to "never clean the carpet in a circular motion" -- which I guess rules out the 'Electrodry' cleaning method and not to use steam cleaning because "all carpets are scotch-guarded when they are made, once they are steam cleaned this is removed necessitating cleaning much more often" -- unless ofcourse you have the carpet re-scotch guarded at considerable expense after the first clean. Arfur, you have confirmed with that MISinformation that you should NOT LISTEN TO CARPET SALES PEOPLE OR LAYERS when it comes to carpet care. They have told you a lotta crap! Firstly, wool does have natural protection from staining, by virtue of its cellular construction. If looked after well, it performs very well. But I have always said to choose wool only if you are going to look after it well. Allowing dogs to live on it may not be a great thing, (possibly an expensive mistake) but some still perform well in these conditions. Yes, having a ROTARY BONNET cleaning method will void the warranty on many carpets, as manufacturers have said it is not acceptable. Manufacturers also say the carpets SHOULD be steam cleaned regularly (AT LEAST EVERY 2 YEARS) and to not do so will void the warranty. Steam cleaning to the Australian Standard is proper maintenance, and does not adversely effect stain resistant treatments if done correctly by trained technicians. So what the installer was telling you utterly wrong! I really do get sick of having to constantly debunk stuff that stupid ill-informed people keep spruiking about carpet care! The stain resistant treatments on a nylon carpet will gradually wear in traffic ways due to abrasion. Proper cleaning with suitable chemicals will not affect this. After the first few cleans, it may be a good idea to have a topical Teflon applied by your technician to restore its performance. This is an investment in the carpet's longevity, and good maintenance. BUT if you fail to maintain the carpet properly, or use an untrained 'carpet cleaner' who do not understand carpets, you may find the carpet's performance declining quickly. And back to the original question... this is an inexpensive carpet that will probably give very good service in kid's bedrooms. http://www.northstatecarpets.com.au/products.asp?id=61 Ash. Re: Best carpet for children's bedrooms 12Feb 01, 2018 3:34 am I was Looking For the best Carpet cleaner And some questions regarding their use so i found this discussion forum.Can Anyone please Suggest Which brand is the best for Safe carpet cleaning? i read in another discussion that your carpet cleaner may damage if its not of good quality. which is the safest nd good Carpet Cleaner need serious suggestion please. Hi, Have fun, remember bedrooms should feel relaxing and inviting, the last space you see before sleep and the first you see when you wake up. Make sure it makes you… 6 16707 1 16721 they can, it's a fairly standard solution when the slab isn't recessed. the falls need to be in the main floor, if it hasn't been done then you need to ask them to redo… 4 7110 |
